Major issues with my timing!
Old Feb 23, 2006 | 04:14 PM
i hate rice's Avatar
Default Major issues with my timing!
I have a ZC
and my engine is making a terrible clanking sound.
And for the life of me I cant get it to stay on TPC
The crank pully and all is ******* off.
And when I spin the cams they just pop right back out of place.
Is this a trick to it that I don’t know about or something?
Cause I’m about to set my car on fire.
Old Feb 23, 2006 | 06:56 PM
Khmi's Avatar
Default Re: Major issues with my timing! (gone in 13 Seconds)
What you mean "pops out of place"...the belt pops out of place?
Old Feb 23, 2006 | 07:00 PM
crxowner's Avatar
i think he means the cam gears if so you could just wedge a screw or something in between them to keep them there
Old Feb 23, 2006 | 09:41 PM
Default Re: (crxowner)
yea the cam gears, they're a ******* bitch *** **** socking motha ******!!!!
ok i feel better now.
i dont know. im about to just put a for sale sign on it and start over with a new car, its been down for a month and has left me with no other option but to drive a 87 honda accord,
Old Feb 24, 2006 | 09:06 AM
ok so again i woke up and i went out working on it. got it all TPC, cranked the motor, withen a few seconds the timing jumped.
i got a new timing belt, new tensioner, new water pump,
so what is causing it to jump?
dude im stumped. does anyone have a guess?
or know of a link with more info on this kinda problem?
any help is greatly appreciated
Modified by gone in 13 Seconds at 1:30 PM 2/24/2006
Old Feb 24, 2006 | 10:48 AM
FOMULA91's Avatar
My friend had the same problem. We tried everything (tighten the timing belt over and over, TDC, and etc…). The only way to solve the problem was to take it to a shop. It was like $50-$70 or so.
Old Feb 24, 2006 | 12:19 PM
ghost_ryder35's Avatar
with the valve cover off, and the cams as close to tdc as you can get them there is a little hole in each of the cams you can put a small screwdrive or a drill bit into. You can get both at tdc that way, and make sure the block is at tdc, and then put the belt back on and tigten that ****, then you can take the drill bits or whatever you put in out. Hope that helped. Because when the belts tight and both cams are at tdc the belt should not let the cams jump any, but with the belt untightened it is a good possibility this will happen, make sure when adjusting it for the proper tension that you dont turn it more then 3 teeth then tighten then turn another three teeth, and maybe one whole rotation then check the tightness of the belt
Old Feb 24, 2006 | 12:33 PM
Default Re: Major issues with my timing! (ghost_ryder35)
i saw those wholes and i was wondering if that was what they were for, im gonna go try that and i'll let you know if that works or not
Old Feb 24, 2006 | 04:31 PM
ok so i got the timing right and TPC and and the belt is good and tight and now the car wont start, JESUS ******* CHRIST!!!!!!
and i broke my ex cam,
any one want a clean 91 hatch with a ZC 1500 its yours come get it
Old Feb 24, 2006 | 05:48 PM
ludesrv's Avatar
Your original problem was your cams where set to TDC with your block. Now you broke a cam. If it's not at TDC and you run it alot you will break valves, which is probably what happenened.
Also, you might of had B16 gears on there...they don't work!
If I were you I'd get some new gears and try again.
Old Feb 24, 2006 | 07:00 PM
Default Re: (ludesrv)
i didn't break it really. just where the CPS goes it. i chipped a nice piece of the end of the cam. and i don't have b16 gears, like i said i honestly am completely baffled by this i don't have the slightest clue what it is,might,could,should, or would be. i'm very close to giving up
fatpride111
10
Nov 20, 2008 07:05 AM
2ltrtodd
30
Sep 21, 2007 05:37 AM
_Bug_
15
Oct 13, 2006 01:10 AM
Voodooboy520
Jun 3, 2006 07:34 AM
94accordsedan
Sep 11, 2005 05:26 AM
