Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Vigor: is it possible to re-wire for independent fog lights?
Old Feb 23, 2006 | 09:27 AM
frostwhite_92's Avatar
Default Vigor: is it possible to re-wire for independent fog lights?
I know that with the DA Integras with JDM lights, you can re-wire it so that the fog lights can be on without the headlights.
Can the same be done with the Vigor? (Non-JDM lights)
Thanks.
Old Feb 23, 2006 | 09:31 PM
Sewer Rat's Avatar
Default Re: Vigor: is it possible to re-wire for independent fog lights? (frostwhite_92)
According to the schematic I've got for my '94, the fog lights run off a relay that is energized through the headlight switch. It would seem that you could either energize that relay seperately from the headlight switch or remove the fog lights from that relay and run them off a different one. The problem will be finding the relay. All the schematic says is that it is in the under dash relay box.
cgjarvis
10
Aug 7, 2016 12:22 PM
JoseCuervo
Lighting
Feb 28, 2012 04:38 PM
teamTakeo
Feb 23, 2012 06:35 PM
Whatislove
Honda Civic (2001 - 2005)
Nov 27, 2008 10:13 PM
