fog lights
Old Feb 19, 2012 | 10:36 AM
teamTakeo's Avatar
Default fog lights
is there a write up or link or instruction someone could help me out with so i can run just my fogs an corner lights? thanks
Old Feb 23, 2012 | 02:52 PM
1ls/vtec's Avatar
Default Re: fog lights
are they the JDM fogs? If so there should be a harness on the front driver side by the headlight to connect the harness to. Then u will have to hook the fog switch up to your fuse box (which slot, I dont remember). I did mine and found how to through google. hope this helps a little
Old Feb 23, 2012 | 04:18 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car?
Not sure what you mean by, "so i can run just my fogs an corner lights" or do you mean you want to ve able to run the fogs without having to turn on the head lights?
What kind of fog lights, make and model? 94
Old Feb 23, 2012 | 06:35 PM
Dannyx321's Avatar
Are you talking about running the fog lights to the bumper lens? So that on the first turn they come on?
punkrrocks
Honda Civic (2006 - 2015)
10
Oct 13, 2009 05:45 PM
