obdII to obdI
i have a 93 civic that had a d15 in it and i just put a d16 into it. i was changing the d16 to obdI so i swapped the alternator, dizzy, injectors, and intake manifold. what my question is, is that i heard i had to switch the clutch and fly wheel too. is this true???
thanks in advance
thanks in advance
no you dont need to change your clutch and flywheel when going from obd2 to obd1. but your left rear lugs nuts you do have to change to go from obd2 to obd1
red civic standard
Jan 9, 2003 06:53 PM
