y7 TB on z6 intake manifold??
Old Feb 23, 2006 | 07:14 AM
Civictimized's Avatar
Default y7 TB on z6 intake manifold??
Can I use a y7 Throttle Body on an z6 intake manifold?
I heard that the TB opens in a different direction on a y7 vs a z6 or a y8 TB... Is this true...
Also if anyone know what are the stock measurements on y7...z6...y8 TB's
Thanks Guys
Old Feb 23, 2006 | 07:18 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: y7 TB on z6 intake manifold?? (Civictimized)
it will bolt right now, the y7 intake manifold is a vertical one, instead of a horizontal one. The tb is the same
Old Feb 23, 2006 | 07:32 AM
Laserjock's Avatar
it will bolt up but the cam where the cable hooks up rotated in a different position so you'll need another cable or rotate the cam. rotating the cam is not recommended cause you'll lose the throttle stop and have crappy idle.
same size opining. i'd post a pic but wetodddidracing is down
Old Feb 23, 2006 | 07:34 AM
Braco11's Avatar
Default Re: y7 TB on z6 intake manifold?? (Laserjock)
actually, the y7 has the iacv on the TB, unlike almost all other honda TB's. i saw a thread once about putting a y7 TB on another intake mani. it can bolt on, but iirc, you have to do something with the iacv.
Old Feb 23, 2006 | 05:07 PM
Thanks guys
TravisCadello
Apr 18, 2009 05:30 PM
90LSpimpin
16
Jan 20, 2005 06:57 PM
RSXrunsit
Jan 19, 2004 08:14 PM
ITSTOCK
Sep 18, 2003 07:58 PM
photonjedi808
11
Feb 18, 2003 10:36 PM
tb, y7, z6
