when do i have to change my rotors? they are 14/16 in
Old Feb 23, 2006 | 07:09 AM
businessmanph's Avatar
Default when do i have to change my rotors? they are 14/16 in
when do i have to change my rotors? they are 14/16 in. thick? i've never had them changed them before. they work fine with little to no grabbing.
Old Feb 23, 2006 | 07:28 AM
Honda_Accord's Avatar
Default Re: when do i have to change my rotors? they are 14/16 in (businessmanph)
Im not a mechanic but, one way to check is to rub your finger on the rotor until u get ot the top and if u feel very it being very ridgy and rough then its probably a good time to change them or ge tthem turned (if u never got them turned before)
Old Feb 23, 2006 | 07:51 AM
TouringAccord's Avatar
H-T Order of Merit
I want to say the max refinishing limit is 23mm or 21mm, maybe someone can tell you for sure. But you need to inspect the thickness with a micrometer or atleast a caliper, I wouldn't say a ruler is good enough.
If you have grooves or pits, it's about time to either resurface them if you can, or just get new ones. Depending on what it's going to cost you to get them resurfaced, you may want to just buy new ones. But then if you buy new ones, you'll have to deal with the whole hub-over-rotor PITA.
Old Feb 23, 2006 | 01:21 PM
hometheaterman's Avatar
Default Re: when do i have to change my rotors? they are 14/16 in (TouringAccord)
They arn't that expensive Nopionline.com has Brembo blanks pretty cheap thats what I run on mine. Those with Nissn or Nissin or whatever it is pads.
Old Feb 23, 2006 | 05:31 PM
sonnieeeeboi's Avatar
to check it accurately, you will need a brake micrometer to check the thickness of the rotor. There should be a minimum thickness value stamped on to the rotor somewhere. Just use the micrometer and measure the thickness and compare. If it is under or near the allowed min. thickness, you change.
Old Feb 23, 2006 | 06:09 PM
RnEpmc's Avatar
Default Re: (sonnieeeeboi)
under what conditions should you change your rotors?
mine are 13 years old i belive. they are in good condition about what businessmanph's look like there are some visible almost like cracks that arnt cracks if that makes sense.
Old Feb 23, 2006 | 07:16 PM
v4lu3s's Avatar
RTFM
21mm is the limit on accord rotors. those are good enough to use for now if your measurement is accurate. they will need to be replaced soon though, 1 more mm of wear ot when they warp whichever comes first.
Old Feb 24, 2006 | 07:20 AM
H-T Order of Merit
Default Re: (v4lu3s)
ok, so 21mm is the thickness.
If the measurement is accurate is the thing. I don't feel you can accurately measure the rotor with a ruler, especially if your possibly talking about only being 1mm (or .039") away from the wear limit. You can buy a set of dial calipers for a decent price, those will give you a more accurate reading. A brake micrometer is the ideal guage to use so you can check further down the rotor, but I don't think it's needed, a caliper will give you a pretty good reading.
Vagitarian
Jun 7, 2012 12:46 PM
LANEVOIX
Jun 23, 2005 04:37 AM
ITR1071
Jan 8, 2003 05:31 PM
BryanS
Jun 27, 2002 08:45 PM
Chairman Kaga
Oct 20, 2001 04:48 PM
