CEL codes? for an JDM h22 in an EG. thinking of buying
Old Feb 23, 2006 | 05:06 AM
16vracer's Avatar
Default CEL codes? for an JDM h22 in an EG. thinking of buying
I'm thinking of picking up a EG with an H22 in it, JDM bottom end with USDM head.
Anyway it's having some issues, here's a copy/paste from the sellers ad:
the throttle response is kind of slow
and sometimes backfires
and cel codes
6 10 12 21 36
He said it backfires sometimes when going down hill or when you are shifting near redline.
Said he took it to a shop and was told: replace water temp sensor and iacv.
Seller says: i would just replace complete intake mani with everything on it so you dont have to guess
but i have hard time finding one
thats complete
He also said the shop said the ECU/Wiring is good and timing is correct.
Does this sound like it just needs a couple sensors? Or does it sound like a big headache?
I'm a VW guy, but I want to pick up a swapped civic for track events.
Not sure if it matters but the car has an intergra dash and cluster and a p13 ecu.
oh well heres a link to the FS ad: https://honda-tech.com/zerothread?id=1450057
thanks
Fred
Old Feb 23, 2006 | 05:15 AM
The Weather Man's Avatar
If you buy that - you're an idiot. NEVER buy a car with problems - because i guarantee that there will be more problems after you 'fix' those.
And you want to replace all the sensors on the IM? Expeeensive............
Old Feb 23, 2006 | 05:22 AM
16vracer's Avatar
Default Re: (TheKINGPin)
thanks for the info man, I've had this little voice in the back of my head telling me no. It's just so hard to find a good swapped hatch around here for less than $4k
Old Feb 23, 2006 | 05:28 AM
Default Re: (16vracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 16vracer &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info man, I've had this little voice in the back of my head telling me no. It's just so hard to find a good swapped hatch around here for less than $4k </TD></TR></TABLE>
Thats 'cause you won't. $4,000 for a hatch w/jdm h22? - i don't see it happening. I suggest you try to find a hatch with 200,000 miles on it. Then buy an h22 and swap it in. Could very well be under 4k in the long run.
Old Feb 23, 2006 | 05:32 AM
16vracer's Avatar
sorry I didn't mean it that way. I'd settle for a b16,b18 or h22
Old Feb 23, 2006 | 05:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 16vracer &raquo;</TD></TR><TR><TD CLASS="quote">sorry I didn't mean it that way. I'd settle for a b16,b18 or h22</TD></TR></TABLE>
yeah. But still $4,000 is kinda pushing it. Hondas and acuras have a really good resale value. I bought my 94 for $5,600.
Any car with an engine swap (major modification) will probably cost more than 4,000 unless something is wrong. THe odds are, if someone does a swap on their car - they'll most likely have other things done - including exterior work. This all takes that value and raises it. So, i say buy a cheap 200k mile hatch and swap your own engine in it. You can probably find a good hatch for $1,000 - if it has really high mileage. Then buy an engine.
djnikko
May 12, 2009 08:38 AM
spoon93
Nov 19, 2007 07:39 PM
SoOHiGH
May 29, 2005 01:59 AM
