ZC in crx...having some problems!!
Old Feb 23, 2006 | 04:55 AM
roadrunner1's Avatar
Default ZC in crx..HELP!!...having some problems!!
I put the zc in my car about a month ago and ever since then it has not run rite...it is fine in first gear but when im at high rpm's in second it falls on its face when i shift gears...not sure of the problem but ive checked several things and still can't figure it out...any suggestions would be very helpfull...thanks
Modified by roadrunner1 at 6:08 AM 3/1/2006
Old Feb 23, 2006 | 05:15 AM
mintef's Avatar
Default Re: ZC in crx...having some problems!! (roadrunner1)
check timing first then get back to me
Old Mar 1, 2006 | 04:16 AM
Default Re: ZC in crx...having some problems!! (mintef)
I dont have the plastic cover on the timing belt to time it...but on some web site it said that the jdm zc is identical to the si wiring...so i was thinkin that could possibly be it but i dont want to take the entire interior/ exterior harness out ...another possibility i thought could be it is tps and map...because its throwing codes 5 and 7...maybe they are switched idk...any info would be helpful
thanks,
Old Mar 1, 2006 | 05:46 AM
SETI20's Avatar
Fix the codes first.
MAP and TPS ar just a little bit crucial sensors. DUH...
You won't rev right in limp mode either.
Old Mar 1, 2006 | 07:34 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadrunner1 &raquo;</TD></TR><TR><TD CLASS="quote"> ...another possibility i thought could be it is tps and map...because its throwing codes 5 and 7...maybe they are switched idk...any info would be helpful</TD></TR></TABLE>
check wire colors on connectors:
MAP should be - yellow/red, white and green/white
TPS should be - yellow/white, green/white and red/blue
Old Mar 7, 2006 | 04:08 AM
Default Re: ZC in crx...having some problems!! (jlicrx)
bump
Old Mar 7, 2006 | 10:33 AM
citystar707's Avatar
Default Re: ZC in crx..HELP!!...having some problems!! (roadrunner1)
Dude go to TheZCR.com......u will find all the information u need about wiring and stuff.....everything u need to know about Any ZC engine is on there...so check it out and get bak to me
civic46
Feb 3, 2007 03:33 AM
kenjo
Jul 14, 2004 06:25 PM
4potnick
Feb 16, 2004 08:55 AM
Digitalcivic
May 28, 2002 09:55 AM
