Retracting antena
Hmm, I would think it would hurt the frequencies. I just replaced mine that was cut down because it was already broken, and I still got 'okay' reception. If you want to replace it and for it to be short, you may want to install an s2000 antenna.
EDIT: You may want to shorten it from the bottom, rather than cutting from the top.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loup05 »</TD></TR><TR><TD CLASS="quote">the s2000 antena is shorter?</TD></TR></TABLE>
yes it is, but I believe there may be some modification needed.
Check here...
https://honda-tech.com/zerothread?id=848582
Here is a DIY https://honda-tech.com/zerothread?id=820243
Check here...
DRKSol
Honda S2000
14
Aug 31, 2005 12:07 AM
greenmonster
17
Sep 23, 2004 06:48 AM
