F22 oil leak.... rear main??
Old Feb 22, 2006 | 05:46 PM
TXSR20DE's Avatar
Default F22 oil leak.... rear main??
My parents have a 97 2.2CL with the F22 in it, and it developed a pretty bad oil leak. I replaced the VC gasket, as it was leaking, and also the oil pan gasket as it was also. Well those aren't leaking anymore, but there is still a leak from somewhere else. Most of the oil collects right where the engine and trans meet, and drips from a lower part of the bellhousing. I think it may be the rear main seal, but don't have the tools here to pull the trans in the garage. Does this sound like it may be the culprit? And does anyone know what a shop would charge to change the rear main seal? Thanks
Old Feb 23, 2006 | 12:45 AM
raceACCORDingly's Avatar
dont know how much they would charge but as of late ive been reading alot of people having the rear main seal leak, starting to become common with f22's.
i had this problem as well.
Old Feb 23, 2006 | 04:00 AM
mac_24_seven's Avatar
Default Re: (raceACCORDingly)
I checked mine out this weekend.. Leaking in the same exact places. I figured it was my rear main.
<sighs>
Blows.
Old Feb 23, 2006 | 06:26 AM
P_Adams's Avatar
Default Re: F22 oil leak.... rear main?? (TXSR20DE)
If you've eliminated all other exterior oil leak sources (valve cover, oil pressure switch) and you're now seeing oil leaking from inside the bell housing; you've only two remaining points of interest.
Engine Rear Main Seal
Transmission Input Shaft seal (Manual) or Torque Converter Seal (auto)
Everything else will show up outside the Bell Housing.
P
Old Feb 23, 2006 | 07:42 AM
SneezinCD5's Avatar
I had the same problem with my 95. 2nd gear went out so I changed it when I put my new tranny in. Took me about 2-3 day with a floor jack for the tranny removal and install It was a bitch putting the tranny back on with it but other than that it was pretty simple. It was worth the work instead of paying $600.00 for a shop to do it. Atleast I know it is done right and eveything is torqued right
Old Feb 23, 2006 | 09:18 AM
TXSR20DE's Avatar
Default Re: F22 oil leak.... rear main?? (SneezinCD5)
yeah, its an auto with 105k.... other than this the car has been flawless since late '96.... my mom just got an '06 TL as a replacement and they are giving this to a relative for a good DD, but I'm off to get an estimate
Old Feb 23, 2006 | 09:34 AM
brads94accord's Avatar
is it oil leaking or does it smell like ATF? I'm willing to bet your original inclination is the culprit.
deeboi
Jan 21, 2013 10:25 PM
dth0ng69
Aug 29, 2009 10:08 AM
m1ndless
Jun 21, 2007 10:09 PM
95LXDRIVER
Dec 1, 2005 10:35 AM
