Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN
Old Feb 22, 2006 | 04:06 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN
Well what appeared to be a tiny crack on my climate face and I wanna gonna fix it with CRX-Toads little face thing turned into a 2 piece climate control, split right beside the temp ****, the 2 wires broken.
This unit is a write off
I dunno what to do, is it hard to install a new factory one? What has to be done really? My dash is apart now so I wanna do it now if possible
Or are there other cars that i can pull a control from and use them? EASILY!!!
I dunno what to do, need help, I should left the ******* thing
Old Feb 22, 2006 | 04:12 PM
CRX Toad's Avatar
Default Re: Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN (TurblowEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF &raquo;</TD></TR><TR><TD CLASS="quote"> I wanna gonna fix it with CRX-Toads little face thing turned into a 2 piece climate control, split right beside the temp ****, the 2 wires broken.</TD></TR></TABLE>
You used one of the plates or you were going to use one?
Old Feb 22, 2006 | 04:18 PM
PINKS's Avatar
Default Re: Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN (CRX Toad)
I knew my climate was cracked but I didnt think when I went and tried to pull it out it would split right inhalf, so now its in pieces on my floor
I dunno what to do, I just read a thread where to install youre faceplate thing and the guys was broken just as bad but his wires didnt break, which mine did
I dunno if I should just trash it and fill the hole with soemthing else or if its worth the effort to fix it
Old Feb 22, 2006 | 04:28 PM
CRX Toad's Avatar
Well please don't trash it. They are useful to piece other climate controls together. Are you able to solder the wires back?
Old Feb 22, 2006 | 04:31 PM
Blaze45's Avatar
Brrraaaap!
I put in the 93 Accrod climate control not too long ago, works great accpet I got 2 wires switched up lol. Ive still got to make mounting tabs for mine tho.
Blaze
Old Feb 22, 2006 | 04:36 PM
PINKS's Avatar
Default Re: Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN (Blaze45)
I dunno if the wires are solderable, I just got ******* mad and my girl was baggin and they popped outta the side that is still hanging
I dunno if I should buy another crx one, try one from another car or just fill the space with something else
I dont remember removing this bracket underneath the unit though, wasnt there, could that of cuased it?
How hard are these things to reinstall?
Old Feb 22, 2006 | 06:57 PM
Reelizmpro's Avatar
You should see my climate control bro. Mine is actually split in two different places. After several set screws, silicone, crazy glue applications and a new faceplate, it looks great and works like a charm!!! I had to take it apart to replace the bulbs, solder those two wires back, brace the temp control **** section by filling the gap with stiff clear silicone. The damn clips that hold the cables broke on me. Fixed that with crazy glue and silicone. Even the geared wheel for the temp selector was broken!!! I sacrificed a perfectly good EF civic one so that the CRX one could be resurrected. Turns out that the civic geared wheel has more bracing on top, so it's less likely to break. ;D
I was looking for another CRX climate control but they are becoming harder to find and the prices keep going up.
Old Feb 22, 2006 | 09:06 PM
PINKS's Avatar
Default Re: Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN (Reelizmpro)
hmmm i dunno what to do, I suck at playing with tiny parts, even more with patience
Old Feb 23, 2006 | 02:29 AM
PINKS's Avatar
Old Feb 23, 2006 | 04:30 AM
SRACHAD's Avatar
put the accord controls in. i wrote up a how-to that's in the FAQ's now
Old Feb 23, 2006 | 05:08 AM
SETI20's Avatar
That looks sweet...but it seemes like a crapload of work tho.
Old Feb 23, 2006 | 06:08 AM
SRACHAD's Avatar
Default Re: (SETI20)
it was tedious when i had to figure out all the wiring on my own. Not too bad though, i think it's more than worth it to have newer looking controls that don't break as easy. Soon i'm going to see if there is a clean way to change the illumination in them from aqua to white or amber. Probably have to remove blue coloring from inside each button so i'm going to practice on a spare set before i risk ruining these.
Old Feb 23, 2006 | 06:43 AM
SETI20's Avatar
did you make a wiring scheme for that FAQ too?
Also, can you de-pin these plugs just like ECU and engine plugs?
Old Feb 23, 2006 | 06:49 AM
fireant's Avatar
I had a crack in mine and I decided to remove it to patch it up. It was very difficult to remove, and I broke it into five peices in the process because the old plastic is brittle and the fit is very tight. I got it all epoxied back together, though, and it looks and works normal now, the cracks show, but it does not rattle.
Old Feb 23, 2006 | 08:00 AM
rsca_crx's Avatar
Default Re: (fireant)
what are mint climate controls going for these days?
Old Feb 23, 2006 | 11:47 AM
Beau Gotti's Avatar
who needs AC/heater core/controls
make a custom block off plate
Old Feb 23, 2006 | 11:52 AM
Reelizmpro's Avatar
Default Re: (rsca_crx)
Good ones sell for around $80-100. Sometimes more. Even the Civic ones are selling for a lot on ebay. People are selling them as CRX climate controls though.
Old Feb 23, 2006 | 11:56 AM
Mr_Si-R's Avatar
Default Re: Climate Control Replacement - How Hard Is It? Other Options! ALL JOIN (SRACHAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRACHAD &raquo;</TD></TR><TR><TD CLASS="quote">put the accord controls in. i wrote up a how-to that's in the FAQ's now
what is the link to that write up...im thinking about doing that now too
PINKS's Avatar
Default Re: (Reelizmpro)
So how exactly do you install the acord one
I cant find any info, crx ones are to expensive to care, I dunno what to do
Old Feb 23, 2006 | 12:08 PM
drdisco69's Avatar
Default Re: (TurblowEF)
Don't kill it, make it shiny and new again with Todds plate.
Old Feb 23, 2006 | 12:10 PM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">what are mint climate controls going for these days?</TD></TR></TABLE>
Are you saying you have some? Bring one to the next RPI autocross you come to...
Old Feb 23, 2006 | 12:53 PM
SRACHAD's Avatar
Default Re: (downest)
https://honda-tech.com/zerothread?id=1434022
There is ALOT of info on how to do stuff yourself in THIS forum under the
CRX & Civic FAQ Version 2.0 thread
My accord climate install is under the do it yourself.
SET120 You might be able to remove the pins in the plugs but i don't thing the clips are the same size. I know for sure the plugs aren't.
How you mount the unit and the air-mix and heater cables are really up to you. I did mine just like in my write-up and have had no problems since. And my A/C works great too.
Any problems and i'll be glad to help.
Old Feb 23, 2006 | 12:58 PM
MDN's Avatar
MDN
Default Re: (drdisco69)
I just put a bid on one of those plates on Ebay.
Old Feb 23, 2006 | 01:00 PM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">
Are you saying you have some? Bring one to the next RPI autocross you come to...</TD></TR></TABLE>
you got a hundred bucks? j/k
i'll see how many extra ones i have.
-greg, who has still never broken one of these...
Old Feb 23, 2006 | 01:04 PM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">you got a hundred bucks?</TD></TR></TABLE>
what is that in beer and lodging?
