94 Accord EX MISSFIRE after warms up????????
Old Feb 22, 2006 | 12:11 PM
AccordEX-T's Avatar
Default 94 Accord EX MISSFIRE after warms up????????
Only Cly #1 missfires after it warms up. But at cold ilde it runs fine. I tryed erveything new plugs, dizzy, injetors. Compression tested it 160 across the borad. Need help!!!!!!
Old Feb 22, 2006 | 01:58 PM
P_Adams's Avatar
Default Re: 94 Accord EX MISSFIRE after warms up???????? (AccordEX-T)
Localized vacume leak effecting the Cylinder1 intake runner. (runs lean once Ecm's auto-rich cycle shuts off)
Leaving the Air Inlet Tube attached, take a can of spray Carburetor cleaner and selectively spray around portions of the Intake Manifold. If you've a vacuum leak the engine rpm will rise as you hit the leak with the cleaner. (It acts as a supplimentary fuel source.
P
Old Feb 22, 2006 | 05:59 PM
AccordEX-T's Avatar
Default Re: 94 Accord EX MISSFIRE after warms up???????? (P_Adams)
I tryed that. No Vacum leak was found.
Old Feb 22, 2006 | 08:32 PM
P_Adams's Avatar
Ignition wires??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordEX-T &raquo;</TD></TR><TR><TD CLASS="quote">Only Cly #1 missfires after it warms up. But at cold ilde it runs fine. I tryed erveything new plugs, dizzy, injetors. Compression tested it 160 across the borad. Need help!!!!!!</TD></TR></TABLE>
P
Old Feb 22, 2006 | 09:40 PM
AccordEX-T's Avatar
I havnt try new ones
Old Feb 22, 2006 | 10:21 PM
P_Adams's Avatar
When next you can find your way under the hood, try this:
Let the engine reach operating tempurature.
If you've got an old spritz bottle around (empty 409 spray bottle etc) fill it with water.
Spray the ignition cables.
If any of them have become pourous and leak voltage the water will force the issue and the engine should start skipping.
What could be happening here is related to dynamic compression and how it requires additional ignition voltage to jump a spark under load as opposed to at idle (no load)
I know we're going into deep theory here, but you've touched on most of the usual suspects already.
P
Old Feb 23, 2006 | 05:12 PM
AccordEX-T's Avatar
Ill try that tomorrow.
Old Mar 1, 2006 | 01:29 PM
AccordEX-T's Avatar
I fixed it!!!!!!!!
2 vacuum lines were swicth for the EGR
ben_tech
Oct 11, 2023 08:41 PM
Henry Juliao
Jan 8, 2022 10:12 PM
20psib20eg
Jul 17, 2011 11:25 AM
Julio
Jun 14, 2010 08:30 PM
bobbysunshine
Jun 29, 2004 12:36 PM
