strut noise
theres a thump noise from passenger rear strut/spring everytime i hit a bump. I thought it was the shock so the shocks are brand new honda ones but still does it. It has Skunk 2 springs and its a 94 coupe and yes i have done a search it wasnt much help. Any ideas would help thank you
I think I have the same problem also. I have narrowed it down to the axle or the front lower ball joint. I have replaced everything else. If you figure anything out let me know.
I've got the same thing going but from the drivers side rear. I recently changed out my ground control/tokico setup. There was a tear in the top hat bushing, might be the cause. I'm bout ready to take it to Honda and let them figure it out.
i had the same problem form both sides and it was that i didnt put the bump stops back in win i put the strut spring assembly back to gather when i put the bumb stops back in the noise was gone when i hit a bump
see i was thinking that about the bumpstop it was a long night that night when i was doing it. Well the other day i found a bumpstop in my toolbox and i think its that one im not for sure im going to check my exhaust piping tomorrow if it aint it its coming apart to check for that bumpstop
i thought about that too, but nope the bump stops are in. took a look underneath last night and noticed a nut missing from one of the sway bar bolts. Thought that could've been it since the bolt was jumping around a lot. Threw a nut on there but that wasnt it. It deffinately sounds like it is coming from the top of the shock/spring assembly. :lightbulb: may be the strut tensioner bolt (terminology?)hrmmm.... looks like i'm back to work tonight.
yh23
10
May 31, 2005 05:11 PM
allicedout
Jun 13, 2004 11:10 PM
