tranny problem shifter moves freely
Old Feb 22, 2006 | 08:51 AM
13sechatch's Avatar
Default tranny problem shifter moves freely
ok so i have a 2000 itr tranny in my car. im driving the other day come to a stop light go to put the car in first and there is nothing there thats right nothing. shift linkage moves back and forth left to right but there are no gears there i can movet he shifter around in a complete circle. i was thinking shift forks but i dont see all 3 going out when i have had no problems out of the tranny at all. clutch pedal and all is fine. anyone have any ideas?
Old Feb 22, 2006 | 07:58 PM
ITR#132's Avatar
Check your shift linkage bolts.
Old Feb 22, 2006 | 08:00 PM
JjuuN R's Avatar
Default Re: (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">Check your shift linkage bolts.</TD></TR></TABLE>
Old Feb 22, 2006 | 09:14 PM
Eddiebx's Avatar
sounds like either the bolts on the shifer fell out. or the bitch pin on the tranny end of the linkage fell off.
Old Feb 23, 2006 | 05:10 AM
citrus3000psi's Avatar
Default Re: (Eddiebx)
Since he doesn't have a type r... Im sure he prolly has a short shifter and the bolt wasn't installed correctly. If if was the spring up front near the tranny..I think the bar would just hit the ground..That would be pretty obvious.
Where as the shifter bar would rest on the staibilzer bar if it was bolt on the shifter itself.
Old Feb 23, 2006 | 08:22 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (citrus3000psi)
Its more than likely not the trans itself. Something about your shift linkage is f@#ked up.
Old Feb 23, 2006 | 08:35 AM
SilverDc2's Avatar
Default Re: (walker111)
shifter bolts may be loose,
check the bushings may be completly gone or ripped, dont forget the bushing on the transmission
Old Feb 23, 2006 | 08:47 AM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">Im sure he prolly has a short shifter </TD></TR></TABLE>
ROFL
I've noticed that too.
Old Feb 23, 2006 | 09:17 AM
sackdz's Avatar
I've seen the shift rod break inside a tranny before... if you don't see anything wrong with the linkage this is probably it.
96ek4dr
Oct 22, 2006 04:46 PM
hondaPINK
17
May 17, 2006 06:09 PM
Crab Man
Apr 27, 2006 08:03 AM
BDogggUT34
38
Apr 11, 2005 02:19 PM
crxman00
12
Apr 5, 2003 09:26 AM
