My motor is leaking oil all over the place...
Old Feb 22, 2006 | 06:26 AM
The_Sober's Avatar
Default My motor is leaking oil all over the place...
So I'm driving yesterday, and I notice I have no Vtec. I figured, since Vtec operates off of oil pressure, that my oil might be low. I swing into the Jiffy Lube my friend works at, and I decide to give it an oil change.
BTW, having a friend who works at Jiffy Lube is great. It makes changing my oil so much easier.
Anyways, I change the oil and filter, and everything looks ok. Then I start the car, and oil starts pissing out of the engine. Not good. When I shut off the car, it stops pissing oil.
It looks like it's coming from behind the bottom end of the timing belt cover. Here's my question: Is there a seal back there? Like a timing belt drive shaft seal that could have blown?
Any (logical) ideas would be greatly appreciated.
Old Feb 22, 2006 | 06:34 AM
SpeedFreak77's Avatar
Default Re: My motor is leaking oil all over the place... (The_Sober)
Front main seal, mine did almost the same thing oil everywhere.
Old Feb 22, 2006 | 06:59 AM
98vtec's Avatar
moderator emeritus
Default Re: My motor is leaking oil all over the place... (SpeedFreak77)
i had this problem awhile back. Kept thinking it was a power steering line broke. It ended up being this service bolt on the back of the block that was shooting oil everywhere. It was close to the timing cover.
u got the jdm motor right?
Old Feb 22, 2006 | 07:27 AM
Honda318dx's Avatar
Default Re: My motor is leaking oil all over the place... (98vtec)
I say front balance shaft seal..
Old Feb 22, 2006 | 08:15 AM
The_Sober's Avatar
Default Re: My motor is leaking oil all over the place... (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">i had this problem awhile back. Kept thinking it was a power steering line broke. It ended up being this service bolt on the back of the block that was shooting oil everywhere. It was close to the timing cover.
u got the jdm motor right?</TD></TR></TABLE>
no, it's a USDM '93 Vtec. Not the most common of Vtec preludes...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">Front main seal, mine did almost the same thing oil everywhere.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">I say front balance shaft seal..</TD></TR></TABLE>
I think it's the front main seal, too. It's behind the timing cover and the balance shaft...
more info to follow
Old Feb 22, 2006 | 08:29 AM
98vtec's Avatar
moderator emeritus
jack the car up...clean everything off...get some goggles and have a friend crank the car for you. Meanwhile, look for where it is leaking
Old Feb 22, 2006 | 10:12 AM
mgags7's Avatar
most likely thats what it is....obd1 h22s dont have the seal retainer....
Old Feb 22, 2006 | 11:38 AM
SteveoBA8's Avatar
Default Re: My motor is leaking oil all over the place... (mgags7)
balance shaft seal poppn out im bettn, retainer is only $3 and it comes with an oil dipstick o-ring. Use thread sealent on the bolts.
Old Feb 22, 2006 | 01:35 PM
Cottonwoodz's Avatar
http://www.autosafety.org/HondaOilSeal.pdf Service Bulletin for Front Balancer shaft oil seal retainer kit
Old Feb 22, 2006 | 03:11 PM
The_Sober's Avatar
Default Re: My motor is leaking oil all over the place... (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.autosafety.org/HondaOilSeal.pdf Service Bulletin for Front Balancer shaft oil seal retainer kit </TD></TR></TABLE>
wow. well, I guess that answers it. Too bad it expired in '03...******' Honda...
more info to follow...
Old Feb 24, 2006 | 12:37 PM
The_Sober's Avatar
update:
front balance shaft oil seal looks to be the culprit. It wouldn't be so bad if all I had to do was install the kit. Unfortunately, the seal backed itself out, so now my timing belt and balance belt are oil-soaked. Need to replace those now, too. Gonna take me the better part of the weekend to replace, I think.
I guess this could serve as a heads-up to anyone else w/ an H22...get the kit and replace it ASAP. The local Honda dealer/rapist still has the kits in stock.
Old Feb 24, 2006 | 01:08 PM
M2B4's Avatar
does this relate to jdm h22's also? if so i need to know asap so i can order the parts i have a week b4 i do my swap.
Old Feb 24, 2006 | 01:16 PM
Default Re: (M2B4)
I would replace It before you install your H22. When you put a new timming belt in..
Old Feb 24, 2006 | 01:19 PM
M2B4's Avatar
Default Re: (Cottonwoodz)
part number is?
06923-p0a-306? i checked and could not find for that or poa-306?
Old Feb 24, 2006 | 01:26 PM
http://www.hondaautomotivepart...83%29
part #13 is the replacement Bracket
You might aswell get #17 Timming Belt, and #23 Auto Tensioner
Ohh, and dont forget the waterpump......
Old Feb 24, 2006 | 02:23 PM
The_Sober's Avatar
I already replaced the timing belt, tensioner, and water pump when I bought the car last August. I believe very strongly in the value of PMs. That's the bitch of it, though. I just replaced the T-belt and now I have to do it again
Old Feb 24, 2006 | 08:52 PM
eluder33's Avatar
a cam seal could also cause this problem, too. It did on my car and the oil pump gasket o-ring thingy was leaking too. I talked to a honda tech here and they said honda put a channel in the timing belt cover to channel oil leaks and such that come from the cam seals.
Old Feb 25, 2006 | 06:23 AM
The_Sober's Avatar
Default Re: My motor is leaking oil all over the place... (mattman33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattman33 &raquo;</TD></TR><TR><TD CLASS="quote">a cam seal could also cause this problem, too.</TD></TR></TABLE>
it's not the cam seal, it's the front balance shaft oil seal...I checked.
kid.dynamite
Jan 24, 2016 09:32 AM
ryaldin
Jan 26, 2015 11:39 PM
Josueneta
May 7, 2010 01:43 PM
pl_masse
Honda Fit
Jun 18, 2007 03:53 AM
tha Big EZ
Jul 2, 2003 08:40 AM
