310CC peak/hold, Low impedance Fuel Injectors... where to get them!?
Old Feb 21, 2006 | 09:20 PM
Driven's Avatar
Default 310CC peak/hold, Low impedance Fuel Injectors... where to get them!?
I'm looking for 310cc injectors that are peak/hold (low impedance) type and can't seem to find any, except one place:
Here!
at $75/each, i'd like to keep looking.
I'm trying to keep my resistor box as it helps keep some of the heat from the fuel rail and in the resistor box, plus the engine builder said it'd be a better idea.
So, any ideas? Searched Google, searched Honda-Tech, searched ebay.
Old Feb 21, 2006 | 09:44 PM
splitime's Avatar
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (Driven)
DSM injectors cheap... and no reason to limit your injector size. Could easily go with a set of 450s... for like 50bucks.
Old Feb 22, 2006 | 02:02 AM
Rywire's Avatar
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (splitime)
the auto dsm is smaller than 440, and low inped.
Old Feb 22, 2006 | 04:32 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">the auto dsm is smaller than 440, and low inped.</TD></TR></TABLE>
390cc/min
*edit
all the other 310cc injectors i can find are high imped....sorry.
Modified by fastcrxsi90 at 12:15 PM 2/22/2006
Old Feb 22, 2006 | 04:45 AM
jdm91CrxSi's Avatar
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (fastcrxsi90)
390cc/min
Old Feb 22, 2006 | 10:23 AM
Driven's Avatar
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (jdm91CrxSi)
I'm shooting for 200whp and don't want to go overkill...
if 390cc isn't overkill... i'll start looking for them
Old Feb 22, 2006 | 10:40 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">I'm shooting for 200whp and don't want to go overkill...
if 390cc isn't overkill... i'll start looking for them</TD></TR></TABLE>
If you are using a chipped ecu or a standalone engine management... the only way to go overboard is by spending tons on huge unneeded injectors. The DSM ones are readily available and usually like 50 a set for the 450s... and the smaller ones are cheaper even.
Old Feb 22, 2006 | 04:22 PM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
If you are using a chipped ecu or a standalone engine management... the only way to go overboard is by spending tons on huge unneeded injectors. The DSM ones are readily available and usually like 50 a set for the 450s... and the smaller ones are cheaper even.</TD></TR></TABLE>
that's the thing... are 390ccs too big for NA w/ chipped ecu or crome?
Old Feb 22, 2006 | 04:24 PM
ef2_civic's Avatar
sent pm of something u might like
Old Feb 22, 2006 | 05:10 PM
Boosted Chemist's Avatar
that's the thing... are 390ccs too big for NA w/ chipped ecu or crome?</TD></TR></TABLE>
i idle 880s on crome, you will be fine the price for dsms u cant go wrong,
Old Feb 22, 2006 | 06:37 PM
hatchblack's Avatar
are the dsm injectors peak/hold or saturated? and if you run those injectors, what kind of engine management do you need for the engine to run correctly?
Old Feb 22, 2006 | 06:42 PM
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (hatchblack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchblack &raquo;</TD></TR><TR><TD CLASS="quote">are the dsm injectors peak/hold or saturated? and if you run those injectors, what kind of engine management do you need for the engine to run correctly?</TD></TR></TABLE>
p/h u need a resistor box like found in stock obd0 multiport civic and crx. U either need a vfac or the prefered way of a chip from Turbo edit or crome or uberdata.
Old Feb 22, 2006 | 07:53 PM
GSRCRXsi's Avatar
Default Re: 310CC peak/hold, Low impedance Fuel Injectors... where to get them!? (Boosted Chemist)
RC makes 320cc P/H injectors. thats what i have and will be using on my 200+ NA GSR build
Old Feb 22, 2006 | 07:56 PM
GSRCRXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">p/h u need a resistor box like found in stock obd0 multiport civic and crx. U either need a vfac or the prefered way of a chip from Turbo edit or crome or uberdata.</TD></TR></TABLE>
and using a resitor box you can still run a obd1 ecu. thats what ill be doing. im gonna use crome.
Old Feb 22, 2006 | 08:08 PM
bks84's Avatar
Loved
If you get to big of injector, it isnt abad thing. You can tune for big injectors, if you max them out, you cant make up for having a smaller injector...
If you have 500c injectors and are only using 400cc thats 80% capacity, thats safe. If you are running a 310cc nad need a 325 or something, then there's no way to make up for the 15cc's you need. That would be using the injector at 104%, recommended usage is usually no more than 80 or 85%.
I hope this is correct info, this is how i've come to understand injectors and ****.
Old Feb 27, 2006 | 08:58 PM
bks84's Avatar
Loved
i guess nobody has any input on that, eh?
DrivinVtec
Sep 17, 2007 10:08 AM
q8delsol
Apr 6, 2007 01:45 PM
deesixteen
Jan 25, 2007 12:43 PM
nick91civicsi
Jul 28, 2006 05:27 AM
wrestler121
Oct 15, 2003 12:31 AM
