help!!!!!!!!!! on my ek, gsr swap and auto to manual
my budy has a 97 coupe.we are going to do a auto to manual swap how hard is it? we are also going to put a gsr motor on it what is needed to drop it in? what kind of axles, mounts, linkage, and he would like to keep power stering would all the hoses just plug up? any other important info you guys can help me out with would be apriciated. thanks.
Your best bet would be to find a donar GSR, that way you have everything from pedals to motor. Because you need EVERYTHING
i have the pedel assembly. ijust want to know how hard is it and what kind of axles, mounts ans linkages do i need.
your going to need the clutch slave cylinder, resevoir, clutch lines that run along the fire wall, shift linkage, shifter, ****, etc. as for the swap, pretty much everything out of a donor GSR, or if you got the cash, get some mounts and junk online. good luck...
Search for it and you'll find all the answers. I use 94+ GSR axles, 94+ Integra Shift Linkages, all Integra motor mounts (rear, driver, and tranny side mounts).. just search for most of your answers wont be hard to find. Good luck!
