anyone that has used after market cams....do you set timing different then stock?
im having trouble setting my timing, and everyone keeps telling me it's because im using aftermarket cams. im throwing a code #9 (#1cyl.) and the lowest i could get my timing was 21*......do i need to do anything different to get my timing right?
also i have adjustable cam gears (right now there both set @ 0*) and i have a pr4 ecu.....the motor is a dohc zc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">some people have to flip there dizzy when throwing nine but I'm not really sure</TD></TR></TABLE> what do you mean? i always thought that a dizzy will only fit 1 way???
by b16 was maxing out at 10 degrees, it was 1 tooth off on the intake side, maybe you are off as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">by b16 was maxing out at 10 degrees, it was 1 tooth off on the intake side, maybe you are off as well</TD></TR></TABLE> yeah im pretty sure im off a tooth......but is that because of the aftermarket cams??<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h224thgensedan »</TD></TR><TR><TD CLASS="quote">I had a delta regrind done in my accord and when i put it back together i was off a tooth on accedent. Check your timing. </TD></TR></TABLE>i know the timing is off.....when you installed the cam did you have to set the timing in a different way?
if you have code 9 and timing is advanced, your camshafts are not aligned correctly
Its easy to align the cams both exactly at tdc, take a tiny screw driver or drill bit and stick it in the whole on the cam shaft right next to the cam gear when they are at tdc and then put everything back together and both will be tdc. I had this problem where I couldnt get my timing right either and it was becuase the exaust side was off 1 tooth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 »</TD></TR><TR><TD CLASS="quote">Its easy to align the cams both exactly at tdc, take a tiny screw driver or drill bit and stick it in the whole on the cam shaft right next to the cam gear when they are at tdc and then put everything back together and both will be tdc. I had this problem where I couldnt get my timing right either and it was becuase the exaust side was off 1 tooth</TD></TR></TABLE>
That is how they show how to do it in the service manual!
hatchinprogress
Feb 7, 2006 06:37 PM
