96 Prelude, What engine Options do I have?
Old Feb 21, 2006 | 07:25 PM
cgilliam's Avatar
Default 96 Prelude, What engine Options do I have?
Background i just picked up a 96 prelude that has a broke timing belt for 600 bux. I am planning on puttin a belt on it and see what kind of damage there is to the values and stuff... But, since this engine is extremely hard to find for a 96.... I was wondering what my options are? JDM replacement? Rebuild the engine myself? I think the h23 has about 160hp, wouldn't mind getting a little more when i am finished... Any Thoughts and options will be greatly appreciated...
Thanks guys...
Old Feb 21, 2006 | 07:32 PM
roller3804's Avatar
Default Re: 96 Prelude, What engine Options do I have? (cgilliam)
ur best option is a JDM replacement.
Old Feb 21, 2006 | 07:33 PM
hu's Avatar
hu
Get a 95 or earlier (obdI). If you plan to build the engine (sleeve, pistons, cams, valvetrain) dont waste $ on JDM. If you just want to put in an engine and be done with it, get a JDM.
Old Feb 21, 2006 | 07:34 PM
cgilliam's Avatar
Default Re: 96 Prelude, What engine Options do I have? (roller3804)
Just the normal JDM 160hp engine replacement? Does anyone know what it takes to convert to a jdm, since the jdm is odb1 and the 96 is odb2?
Thanks Guys
Old Feb 22, 2006 | 06:36 AM
kulrevon's Avatar
just use intake manifold,dizzy, and oil pump off your old engine.
Old Feb 22, 2006 | 07:17 AM
cgilliam's Avatar
Default Re: 96 Prelude, What engine Options do I have? (kulrevon)
So I can get a JDM engine, then just put on all my external and they will bolt on with out any problem? then everything will work?
Old Feb 22, 2006 | 07:23 AM
Chronic H22's Avatar
Maybe but dont waste your time on an H23, Go with the H22.
Old Feb 22, 2006 | 07:28 AM
98vtec's Avatar
moderator emeritus
Default Re: 96 Prelude, What engine Options do I have? (Chronic H22)
b16 ftw!
Old Feb 22, 2006 | 07:30 AM
cgilliam's Avatar
from what i have been told in order to get a h22a ( which is a vtec) is tht i have to have an ECU out of a 96 only? Is this true?
Old Feb 22, 2006 | 07:31 AM
97Preludeguy's Avatar
Default Re: 96 Prelude, What engine Options do I have? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">b16B ftw!</TD></TR></TABLE>
Fixed y0!
Old Feb 22, 2006 | 07:55 AM
ludesrv's Avatar
Just do an OBD1 conversion and use the OBD1 ECU. If your gonna go crazy with cams, OBD1 is the easiest/cheapest to tune.
HondaTechMan121
Jun 17, 2016 07:34 PM
717DC
Nov 20, 2009 06:34 PM
DrKRD
Apr 10, 2009 09:26 PM
