i bet you cant figure this one out..
my friends 2000 gsr is getting no spark at all. he just parked it, came back out to start it up and nothing.
here is a list of what has been checked or replaced:
-ICM
-coil
-voltage and wiring to the dizzy
-ecu
-timing belt
-ALL grounds
-rotor
-cap
-spark plugs
-plug wires
-ignition switch
-ALL fuses
i think that is it..
-ICM
-coil
-ecu
-timing belt
-ALL grounds
-rotor
-cap
-spark plugs
-plug wires
-ignition switch
-ALL fuses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypRice »</TD></TR><TR><TD CLASS="quote">did you check the igniter in the dizzy?
not the ign. coil.</TD></TR></TABLE>
yes its on the list..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">most likely its a cut wire somewhere
take it to an electrition</TD></TR></TABLE>
how can a wire just cut itself while sitting there parked?
besides the dizzy is getting voltage. all wiring has been checked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">
-ICM
-coil
-ecu
-timing belt
-ALL grounds
-rotor
-cap
-spark plugs
-plug wires
-ignition switch
-ALL fuses
i think that is it..</TD></TR></TABLE>
You forgot the Battery. But, it could be alarm related.
-ICM
-coil
-ecu
-timing belt
-ALL grounds
-rotor
-cap
-spark plugs
-plug wires
-ignition switch
-ALL fuses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypRice »</TD></TR><TR><TD CLASS="quote">whats happening what you try to start?
nothing at all or just cranking with no catch?</TD></TR></TABLE>
just cranks and doesnt start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote">You forgot the Battery. But, it could be alarm related. </TD></TR></TABLE>
battery is putting out 12.8 volts. and no alarm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTI »</TD></TR><TR><TD CLASS="quote">main relay.</TD></TR></TABLE>
how does a main relay control spark?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">how does a main relay control spark?</TD></TR></TABLE>
It controls fuel. how do you know the problem wasn't fuel related?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreww.. »</TD></TR><TR><TD CLASS="quote">Tap on the starter a few times....Seriously.</TD></TR></TABLE>
explain how that causes the no spark?
there is no spark at all in cylinders 1,2,3,4
how do i know?? uh you put a spark plug in the end of the plug wire and ground the electrode and have someone crank it over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecmissle »</TD></TR><TR><TD CLASS="quote">what about the crank positioin sensor. Check that and make sure it didnt disconnect.</TD></TR></TABLE>
can the sensors inside the dizzy cause it to get no spark at all? i mean by grounding the spark plug to check for spark, not with it all together and trying to start the car..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">are you sure it's getting fuel?
parked as in a few hours, or months?
how did u check those things you listed? by the book or just ya it looks good! ?</TD></TR></TABLE>
its getting fuel.
parked for a few hours.
checked it all by the book and replaced alot of stuff..
...i think he's is just going to need a new dizzy.
its getting fuel.
nobody said this but did you put the wires where they should be, for the spark plugs. if you screw up the order you will crank but not start. i know i had the same problem. just check out if your wires are where they should be for your dist. and on the engine.
