does anyone know what the valve adjustment spec's are for 95accord ex?
Here you go. This should get you started.
intake: Low Limit = .009" High Limit = 0.011"
exhaust: Low Limit = 0.011" High Limit = 0.013"
Chiltons' and Hanes both report the same values for the F22a1, F22b1, F22b2 thru '97 and C27a4 for the '96 and '97 model years
P
Modified by P_Adams at 1:34 PM 2/22/2006
P
Yes. To do it properly each cylinder must be positioned at TDC (Top Dead Center) on the Compression Cycle. It's the only position where both the intake and exhaust valve followers are resting on the cam base circle; where they can be adjusted.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">.006-.007 Intake///.007-.008 Exhaust From Alldata tables</TD></TR></TABLE>
we must be looking at different All-data tables.... the one i look at .. says
intake 0.26 mm .. 0.010 in
exhauast 0.30 mm.... 0.012 inc.............
...And i know mine is correct because it says the same thing on the helm book..
