Solid Mounts D16 into 88-91
Old Feb 21, 2006 | 06:31 PM
boostedb16a3's Avatar
Default Solid Mounts D16 into 88-91
Modified by boostedb16a3 at 11:57 PM 9/2/2006
Old Feb 21, 2006 | 06:43 PM
e jay one's Avatar
Default Re: Solid Mounts D16 into 88-91 (boostedb16a3)
ive got some inserts for all 4 mounts ill sell you for cheap. there very solid probably too solid for a single cam the motor doesnt even move but its gonna rattle your car.
Old Feb 21, 2006 | 07:01 PM
Default Re: Solid Mounts D16 into 88-91 (e jay one)
I'm building a 500whp SOHC Vtec Turbo. I need solid mounts. Do you have pics? send to jjeanlouis@yahoo.com
So this is an actual insert pressed into an OEM mount?
Old Feb 21, 2006 | 07:22 PM
EF_generation's Avatar
Default inserts
Usually the way inserts work is that they are usually made of poly eurethane and what they do is fill out the gaps in your rubber stock mounts, but they still LOOK like after market mounts made with stock metal, if you know what I mean. But the downside he was bringin up is that since the mounts don't flex anymore, vibrating motor=vibrating chassis. Good for power, bad for comfort
Old Feb 21, 2006 | 07:58 PM
Ak_ef9's Avatar
Default Re: inserts (el_payaso)
if you got solid mounts that could severly damage your subframe and it will rattle the crap out of the car. If you just got some full race poly mount inserts then that will be more then sufficient.
Old Feb 21, 2006 | 09:56 PM
killa rex's Avatar
you can try Prothane inserts...i used it for 2 mounts(tranny side and timing side)..but the problem was that, it rattled the **** out of the car..so after 2 days of it, took out the timing side..but anyways..the Prothane are for drag/turbo setup..so this might be up your alley..
check ebay they have it all time.
Old Feb 22, 2006 | 02:13 AM
thanks for the info guys. I just wish there was a mount kit out there, that was readily available like what hasport makes. I'll def. check out ebay.
Old Feb 22, 2006 | 02:32 AM
A few quick questions:
Do you think I am going to need to purchase brand new oem mounts and then buy the inserts? Or do you think I can find some used free mounts and then do the inserts? I found some inserts for a 92-95 civic, but I presume at least two of the mounts are different from the 88-91 right?
Old Feb 22, 2006 | 04:35 AM
driveahonda's Avatar
Couldn't you just buy the hasports then modify them to work correctly?
If you can get 500hp out of an A6.. then this shouldnt be a problem.
Old Feb 22, 2006 | 07:03 AM
HumanResource's Avatar
I drilled holes in the "Place" units I had when I was B16'd
toned down some of the vibration
Old Feb 23, 2006 | 09:29 PM
I think im going to pick up some prothane inserts, and use 3m window weld. Extra solid mounts.
Old Feb 23, 2006 | 09:52 PM
killa rex's Avatar
Default Re: (boostedb16a3)
trust me..the prothane inserts are hard as F@#$. hard as a rock. you see what i mean when u get them
Old Feb 23, 2006 | 10:02 PM
jisu009's Avatar
Default Re: (xmunxjai648)
In for the dyno graph of the 500HP A6 yO!
Old Feb 24, 2006 | 03:12 PM
Default Re: (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">
In for the dyno graph of the 500HP A6 yO!</TD></TR></TABLE>
It's actually going to be a
Z6 block / Y8 head. I will
start a thread once everything is
underway.
cruizer
Sep 15, 2009 07:24 AM
smokey.23
22
Mar 24, 2009 09:01 PM
clem kevin
May 1, 2008 06:57 PM
pubestripe
Oct 3, 2005 09:29 PM
jdm92teg
Jun 26, 2005 11:19 PM
