Is there a special key to install stock cam gears?
Old Mar 28, 2002 | 07:48 AM
guyuenvy's Avatar
Default Is there a special key to install stock cam gears?
I had a problem withthe head on the gsr. Took it out to find a bad head gasket. When I put the head back on got everything on a Iw as with a mecahnic and he says the cam gears stock have a special key to put them back on. When I took it off there was only bolts. Is there a special key to put the gears back on?
Old Mar 28, 2002 | 10:21 AM
94civicx's Avatar
New User
Default Re: Is there a special key to install stock cam gears? (guyuenvy)
there should be a woodruff key that is needed to install the cam gear onto the cam. go to a auto store and they are like 50 cents. Just make sure you get the right key that fits in the groove on the camshaft.
Old Mar 28, 2002 | 10:13 PM
t's Avatar
t
Before you start your car, use a magnet and shove it down at the crankshaft gear and waterpump gears to make sure that the stock keys arent wedge in there when you took the gears off in the first place. You will have problems if it is in there.
Old Apr 2, 2002 | 10:23 AM
SCsol's Avatar
Default Re: Is there a special key to install stock cam gears? (t)
make sure you get the right key or you will run into big problems go to honda or acura and get the proper one "T" good idea about the magnet
JDMflavor_EJ
Aug 7, 2005 04:29 PM
graphic
Apr 12, 2005 10:45 AM
Mark
Oct 19, 2003 09:39 PM
boostin b16
Mar 18, 2003 07:13 PM
guyuenvy
Mar 28, 2002 08:45 AM
