Could someone with an EF Momo Steering wheel adapter do me a favor?
hmm. well, what's the 'base?' the part that contacts the turn signal return inside the column cover, or the black part outside of the column cover?
i have 3 7/16" from steering wheel mounting surface to bottom of black trim 'base' of hub and 1/4" from this base to plastic column cover. i think the 4 3/8" measurement is total height.
i assume you want this info to determine spacer or quick release size?
Mostly just wondering how much a dish I'd want with a steering wheel, since due to the seating position/wheel distance I have to sit with my head nearly touching the headliner. By base I meant the outer metal part of the hub that is right next to the plastic cover on the steering column.
Thanks Lee, I'd appreciate that. I'm not real tall, so I end up real close to the headliner, as you can see here. I was looking at the 70 mm and 90 mm dished wheels that Momo sells as an option.
skoolz
Honda Civic (2006 - 2015)
Mar 19, 2015 05:14 AM
Civic_07
Jun 26, 2008 12:23 PM
