Suspension & Brakes Theory, alignment, spring rates....
Alignment Results: Suspension Gurus... PLEASE HELP????
Old Feb 21, 2006 | 08:07 AM
rmdolatre's Avatar
Default Alignment Results: Suspension Gurus... PLEASE HELP????
What might be causing this!!!????
Old Feb 21, 2006 | 08:47 AM
AutoXer's Avatar
Default Re: Alignment Results: Suspension Gurus... PLEASE HELP???? (rmdolatre)
Your camber looks okay, the left rear looks a little odd that it's positive. The front toe looks great, and the left rear is off a bit, although I'm not what that is in inches. Did you bend something in the LR?
Old Feb 21, 2006 | 08:48 AM
Erik95LS's Avatar
Are you lowered? If so then thats pretty acceptable camber.
Old Feb 21, 2006 | 09:13 AM
AutoXer's Avatar
Default Re: Alignment Results: Suspension Gurus... PLEASE HELP???? (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">Are you lowered? If so then thats pretty acceptable camber.</TD></TR></TABLE>
But he has positive camber in the LR, with bad toe. If the toe adjustment is maxed out, something is most likely bent on that corner. LCAs bend if you look at them the wrong way.
Old Feb 21, 2006 | 09:17 AM
Tyson's Avatar
Default Re: Alignment Results: Suspension Gurus... PLEASE HELP???? (AutoXer)
everything looks good except the LR. something funny going on there. if it hit a curb or sometihng, that would explain it. probably a bent trailing arm, but thats just a guess. who knows.
Old Feb 21, 2006 | 09:21 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">But he has positive camber in the LR, with bad toe. If the toe adjustment is maxed out, something is most likely bent on that corner. LCAs bend if you look at them the wrong way.</TD></TR></TABLE>
Yeah I missed that rear number. Something is definitely amiss on that corner.
1oldroaddog
Honda Civic (2006 - 2015)
Nov 9, 2007 05:21 AM
FalkenSiR
Suspension & Brakes
Jun 6, 2006 11:06 AM
john d
Apr 7, 2005 07:26 PM
Wazup
63
Feb 7, 2004 06:54 PM
Andrew 825SM
Aug 15, 2003 03:16 AM
