spline hub?
Old Feb 21, 2006 | 08:05 AM
EJ8 GSR-T's Avatar
Default spline hub?
so i am looking into new axles for my b16 swap but i have been told i need 28 spline hubs! can anyone please explain what this is about!!thanks-
Old Feb 21, 2006 | 08:13 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: spline hub? (userdead626)
If you are looking for new axles for your swap, just get axles for your engine.. It shouldnt be rocket science.
B series axles of the same engine generation are interchangable as well. That means B18 axles will work with a B16, etc.
Old Feb 21, 2006 | 08:25 AM
EJ8 GSR-T's Avatar
Default Re: spline hub? (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 &raquo;</TD></TR><TR><TD CLASS="quote">If you are looking for new axles for your swap, just get axles for your engine.. It shouldnt be rocket science.
B series axles of the same engine generation are interchangable as well. That means B18 axles will work with a B16, etc.</TD></TR></TABLE>
yes i am not an idiot but i am going for 350hp so i figured if i have to get axles anyways i should get better ones, but i was told that along with upgraded ones i should also get 28 spline hubs....
Old Feb 21, 2006 | 10:48 AM
EJ8 GSR-T's Avatar
bumo
Old Feb 21, 2006 | 11:05 AM
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">yes i am not an idiot but i am going for 350hp so i figured if i have to get axles anyways i should get better ones, but i was told that along with upgraded ones i should also get 28 spline hubs....</TD></TR></TABLE>
Ok.. next time you post, post ALL the information. You should have said that in your original post. Learn to communicate.
I dont know about how many splines you should get. Go to driveshaftshop.com and check out what they say about it. They sell axles all the way up to 1000+hp.
Tuski_EF
Jan 18, 2016 10:17 PM
SLPN H
Aug 14, 2008 08:52 AM
JDMotive
Aug 4, 2004 08:54 AM
flyingduck04
Jan 16, 2004 08:49 AM
