How to install Block Guard?
Old Feb 21, 2006 | 07:33 AM
PhatBoy5015's Avatar
Default How to install Block Guard?
I know which side goes down, but on one side of the guard there are the letters "ADD". I was wondering if this goes on the exhaust side or the intake side. Or does it even matter? Both sides look identical.
I was also wondering if there was a special way to install it. Do you just put it in there and tap it down with a rubber mallet or something?
Old Feb 21, 2006 | 10:32 PM
Default Re: How to install Block Guard? (PhatBoy5015)
So does anybody know if it is supposed to be just tapped in with a mallet? Or some special way to do it?
Old Feb 21, 2006 | 11:59 PM
riceball777's Avatar
please search
if you search you would know that most people do not recomend block guards and if you really want to install one you need to take you block to a machine shop and they will weild it in in a few spots
do not ust tap it in with a hammer!!!!!!!!
Old Feb 22, 2006 | 05:48 AM
K-Drum's Avatar
mine (KMS unit) was lightly tapped in with a rubber mallet, then used a punch to have it a little lower than the deck to aid in cooling the top of the sleeves (about 1/4 to 1/2" is enough) now once the guard is in, have the block honed or checked to ensure that it's not out of round. once done re-assemble.
after mine was installed the block was bored to the size of the new pistons, I have not experienced any overheating, or any drawbacks from having it installed.
Old Feb 22, 2006 | 05:59 AM
TURBODC4TEG's Avatar
Default Re: (K-Drum)
nice pic i bought the same block guard, guess i'm gonna have mine spot welded and then honed
fatboys_ef9
Nov 3, 2009 10:41 AM
crampinyourstyle
Aug 12, 2006 06:10 PM
dohdoh420
Feb 21, 2006 10:43 PM
FMIDRC Racer
Feb 14, 2005 11:48 AM
