ex and si front swaybars, same?
Old Feb 21, 2006 | 07:28 AM
whitelightning's Avatar
Default ex and si front swaybars, same?
couldn't find it in the archives. a front si sway bar is 26mm, what is the size a 96 EX? wondering if an upgrade would be worth it...if they are different. thanks
Old Feb 21, 2006 | 08:20 AM
JokerX-1.6T's Avatar
Default Re: ex and si front swaybars, same? (whitelightning)
No they are diff sizes and to go from ex to si you need to swap all the front out being the lower control arms , to accomadate the diff mounting points for the si sway bar and shock forks also - which would also be vice versa from si to ex
I changed mine out from the ex front suspension the the si
Modified by JoKeRX at 12:36 PM 2/21/2006
Old Feb 21, 2006 | 11:15 AM
Default Re: ex and si front swaybars, same? (JoKeRX)
darn...thought it would be an easy swaybar swap....thanks for the input!
Charlie Moua
Dec 12, 2013 08:23 AM
b20beast83
Suspension & Brakes
Jul 18, 2009 07:47 PM
SHG_Beans
Suspension & Brakes
Jan 3, 2007 02:22 PM
jennifermike
Feb 27, 2006 01:19 PM
BanEL
Mar 20, 2004 06:33 AM
