Need some help: ID these Ohlins
Hey does anyone have a part number for these? or a model name? So I can at least try to look for some info on it. They're 30 way adj. and you can't change the ride height. Any help will be greatly appreciated.
thanks!!
thanks!!
Those are the older pre pcv ohlins.
The ride height is adjustable. You have to remove the upper pillow mount and spring so you can adjust the lower perch.
Once the spring is off(or I guess you could use a spring compressor) you slide up the lower perch and there will be a wire clip setting in one of 3 or 4 grooves. Slide the wire clip into your desired groove and lower the perch onto it.
Still a very good setup even though it is not the latest and greatest.
You can just barely make out one of the wire grooves (above the perch) in this picture. This was a EF8 setup I was using on my eg6.
I later upgraded to a newer set of pcv's.
kaluwa3
Suspension & Brakes
May 13, 2007 03:39 PM
u2civic1
May 5, 2004 03:52 AM
