Intake gasket wild idle HELP!
Can installing an intake gasket from a 92+ civic onto a 91 civic intake manifold cause irratic idle? Because the manifolds are slightly different where the water flows throw. For example the 92+ is circular (round) and the 91 manifold water thingy is kinda squared like
l \
l l
------- <--- kinda how the 91 intake manifold looks but i used the OEM 92 + intake gasket. Is it possible that the water didn't seal correctly and goes into the intake? THis is on a D15B2 motor.
*****GO to last post for solution******
Modified by blue_dlb at 11:16 AM 3/5/2006
l \
l l
Just had problems with my IM gasket, get a new OEM one that is meant to go your engine and call it a day. You don't want any vacuum or coolant leaks, especially in the intake area.
I can't believe it was the spark plugs. I changed the spark plugs and all the problems have gone away. IT could have also been that the ground wire on the thermostat housing was also loose. So one of the two.
Modified by blue_dlb at 7:06 PM 3/5/2006
singlecammin
Jan 20, 2011 07:20 PM
qpzm12
Oct 4, 2010 03:19 PM
ilu
Apr 19, 2006 03:08 PM
ULTRA911
Mar 4, 2003 10:00 AM
