Changing O2 sensor....how hard?
Old Feb 20, 2006 | 05:00 PM
92 honda ex's Avatar
Default Changing O2 sensor....how hard?
Tomorrow I'm going to change to o2 sensor on my g/f '92 EX. Is there any difficulty in doing this? Any tips?
Should I disconnect the battery to clear the code(41) then?
Modified by 92 honda ex at 3:58 PM 2/21/2006
Old Feb 20, 2006 | 05:04 PM
f22b-dohc's Avatar
Default Re: Changing O2 sensor....how hard? (92 honda ex)
installation is reverse of removal
7/8 is what i use cuz i dont have a the o2 socket
Old Feb 20, 2006 | 05:20 PM
Ross 2.0's Avatar
In a Junkyard near you.
I use a 7/8 crows foot to get it out.
Everybody usually clears the code after the repair is done. It's easy as long as the sensor isn't seized in the hole.
Old Feb 20, 2006 | 07:09 PM
iam7head's Avatar
Default Re: (MooGoCow3)
just remember to put anti-seize when you putting it back on
Old Feb 20, 2006 | 07:10 PM
What do you do if it IS seized in the pipe..............punt?
Old Feb 21, 2006 | 11:03 AM
iam7head's Avatar
Default Re: (92 honda ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 honda ex &raquo;</TD></TR><TR><TD CLASS="quote">What do you do if it IS seized in the pipe..............punt?
if you don't plan on using it again, spray some silicone lube while it's warm and then use a breaker bar.
Old Feb 21, 2006 | 02:58 PM
Default Re: (iam7head)
Well....it looks like that &*#!@ is seized pretty good. No matter what I tried, it won't budge! I had to quit before I rounded off the edges.
Looks like it's going to the shop! Anyone know what that book time is on that job?
Old Feb 21, 2006 | 05:16 PM
Default Re: (Group A)
Yep, I tried everything.....won't move! I was told it would be much easier if I had the correct tool to do it. How much does that tool cost?
Anyway, the book time on this can't be very long. It's like changing a spark plug but I just can't get it out. Other than that, it should be a 10 min. job
Old Feb 21, 2006 | 05:18 PM
Eddiebx's Avatar
why dont u get a o2sensor wrench and try again with a long breaker bar. shouldnt cost more than 10 bucks at vatozone for a socket
EJ8_Enthusiast
Sep 16, 2008 03:15 PM
JB-HRC3
33
Feb 6, 2008 05:28 AM
4DRmafia
Nov 20, 2006 04:55 AM
daRk kNight
Oct 20, 2005 09:22 AM
tony d
Aug 7, 2004 03:17 PM
