water in my 98-01 all-read tails..
Old Feb 20, 2006 | 03:13 PM
TiredToyotaDriver
Guest
Posts: n/a
Default water in my 98-01 all-red tails..
whats up all... I just got some 98-01 all-red coupe tail lights... but when I got them, they had water in them! My friend that sold them to me says that it is because the tail light gasket is no good, and the water got in that way... there isnt a whole lot, but it is mainly AROUND the reflectors and turn signals... I've never seen this before... can anyone verify whether or not this will be fixed by a tail light gasket or if these lights are junk??
Old Feb 20, 2006 | 03:19 PM
. M i c h a e l's Avatar
dotmichael to you
Default Re: water in my 98-01 all-red tails.. (TiredToyotaDriver)
this happens on all tail lights, you can get a new gasket from honda (30 bucks or so if i remember correctly) or just open them up...dry them out and put some silicone and slap them back together. basically the seal goes bad, its an easy fix either way.
Old Feb 20, 2006 | 05:06 PM
Cliffjumper2's Avatar
yes, the tail light gasket should help.
moisture in the tail lights and hatch area is a common problem on the tegs
Old Feb 20, 2006 | 05:42 PM
magicksdc2's Avatar
just solved this problem on my car with a pair of brand new factory tails (my previous ones had the corner broken off where it meets the quarter panel) but my gaskets had also gone south. replaced one gasket and used silicone to seal the other and havent had any water in my lights or spare tire well since.
Old Feb 20, 2006 | 07:51 PM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: (mgx98 ssbp gsr)
so my tail lights are not junk? the prob is the gaskets?
Old Feb 20, 2006 | 07:56 PM
tegG2's Avatar
Default Re: (TiredToyotaDriver)
most likely.
Old Feb 20, 2006 | 11:51 PM
twenty20hindsight's Avatar
And here I thought I was going to get a cool title
My car came like that too. I just put silicone around them to seal any leaks. No more water could get in and the condensation eventually dried. I found an article on it before, but I'm feeling too lazy to look for it now. If you want it, ask me and I'll post it up.
Old Feb 21, 2006 | 04:34 AM
be.twenty's Avatar
just replace the gaskets
Old Feb 21, 2006 | 05:53 AM
TiredToyotaDriver
Guest
Posts: n/a
Default Re: water in my 98-01 all-red tails.. (twenty20hindsight)
put silicone around them... meaning, you put silicone around the outside red reflecting plastic stuff?? I've read that article on 'drying out and sealing your aftermarket tails' on team-integra... just need to know if the problem is with the headlights, or if it is just the gasket.... I'll find out soon, i suppose!
vega_ROCKS
Dec 18, 2008 12:19 AM
SHG_Beans
Oct 24, 2006 06:09 PM
TehMoonRulz
22
Apr 22, 2006 04:16 PM
TXGirl
Jul 7, 2003 02:48 PM
