Help!!! Car won;t start!!!
Old Mar 27, 2002 | 09:50 PM
E46M3CB's Avatar
Default Help!!! Car won;t start!!!
Ok here's what has been changed since the last time it started:
New Clutch & Flywheel Installed
New O2 Sensor Installed but not connected
New NGK Platinum Spark Plugs
New MSD Ignition Upgrade (6A, Distributor Cap, Wires, Blaster Coil)
New Autometer Oil Pressure Gauge (Used T-Tap at the oil sensor area)
New OEM Fuel Filter
I have no idea whats wrong with the car now at this point, The car will turn when you crank it but it will not start... I put the ignition back to stock and it still wont start... It just keeps on cranking but that's it... I have spent 5 hours trying to figure whats wrong with no luck... Can someone on this board please help...
Thank YOu
Old Mar 27, 2002 | 10:00 PM
Chris's Avatar
Default Re: Help!!! Car won;t start!!! (serenity)
Fuel filter... is it one way only? Could it be backwards?
Old Mar 27, 2002 | 10:12 PM
Bob#455's Avatar
The R does NOT need aftermarket ignition or spark plug wires...and in fact most setups will give you little problems here and there. Return those back to stock, and if it still doesn't work, I don't know...
Old Mar 27, 2002 | 10:18 PM
Chris's Avatar
Default Re: Help!!! Car won;t start!!! (Bob#455)
Thats why I say fuel.
Old Mar 28, 2002 | 04:40 AM
BudMan's Avatar
Default Re: Help!!! Car won;t start!!! (Chris)
I don't recall, but I believe you may have to leave the key on to bring fuel back up to the filter. Did you just try & start it right away, or did you leave the key in the "on" position to allow the pump to refil the filter & push fuel all the way to the injectors?
I'd re-examine the fuel filter install immediately.
Old Mar 28, 2002 | 05:18 AM
E46M3CB's Avatar
Default Re: Help!!! Car won;t start!!! (BudMan)
There's only one way to put teh fuel filter on...
Ok here's all the things in which I have done to troubleshoot it but all has failed...
I check the spark plug wires to make sure that there are sparks and sure enuf there is.
I checked teh new fuel filter to see if there is any gas in there and yes there is also
I checked teh ground for the transmission and yes there is too
I then checked the alternator and everything is connected ( I removed this also to install aem power pulley)
I checked teh starter and everything is also properly connected.
I checked my battery and everyting is fine ( I moved teh battery to teh trunk also)
The reason why i did teh ignition upgrade was b/c my friend gave it it to me...
My radio works fine all electrical on my car works fine... The car will turn when i try to crank it but it won;t start... I am stumped... please help...
Old Mar 28, 2002 | 05:21 AM
SwiftTypeR's Avatar
New User
maybe u need a new starter?
Old Mar 28, 2002 | 05:25 AM
E46M3CB's Avatar
Default Re: Help!!! Car won;t start!!! (SwiftTypeR)
I highly doubt it because the motor cranks but it doesn;t start... if it was the starter then it would just click right n not even turn? correct em if i am wrong anyone that can heklp please do..
Thanks
Old Mar 28, 2002 | 06:12 AM
TypeR0149's Avatar
Stupid Question but is the distributer plugged in
Old Mar 28, 2002 | 06:25 AM
BudMan's Avatar
Default Re: Help!!! Car won;t start!!! (Vegeta)
maybe your friend gave you the msd 'cause it sucks? Actually - I don't remember if the msd is adjustable to 4/6/8 cylinders or not...if it's like a tach that is adjustable, you better make sure you've got it set right or it won't allow spark to flow at the proper time to fire the car.
jmho - I'd take the damn msd off anyway - you don't need it.
[Modified by BudMan, 9:26 AM 3/28/2002]
Old Mar 28, 2002 | 06:35 AM
Balls's Avatar
Stupid Question number two... did you set the timing?
Old Mar 28, 2002 | 08:44 AM
E46M3CB's Avatar
Default Re: Help!!! Car won;t start!!! (*****)
well its not the msd b/c i have set the ignition back to stock and it still won;t start it only turns...
in regards to timing i never took my distributor off only the cap so i donlt see a reason to adjust timing...
please help if anyone has idea please let me know i am currenlty trying to trouble shoot it...
Thanks
Old Mar 28, 2002 | 08:46 AM
AssPenny's Avatar
Have you checked to see if you have spark at all? Pull a plug and put it in the plug wire. lay it on the valve cover nut (or anywhere so i can ground out) and see if you get a spark from the plug. This will help you debug the problem a little more.
Old Mar 28, 2002 | 08:48 AM
E46M3CB's Avatar
Default Re: Help!!! Car won;t start!!! (AssPenny)
yes done that already and there is spark
Old Mar 28, 2002 | 08:50 AM
MPH's Avatar
MPH
New User
Is there gas in the tank?
E46M3CB's Avatar
Default Re: Help!!! Car won;t start!!! (MPH)
yes also i just dumped 2 gallons of gas in there...
Old Mar 28, 2002 | 08:51 AM
AssPenny's Avatar
Is your fuel pump running? Do your injectors get power/signal? Have you checkt he injector fuse (I think there is one in the fuse panel under the hood by the battery, but i've been known to be wrong.)
Old Mar 28, 2002 | 08:53 AM
MPH's Avatar
MPH
New User
Are the starter teeth grabbing the flywheel all the way?
Old Mar 28, 2002 | 08:54 AM
E46M3CB's Avatar
how do i check if the fuel pump is running what about the injectors? how do i go about chking that also?
how do i check if the starter teeth is grabbing the flywheel? it in all the way
[Modified by serenity, 10:01 AM 3/28/2002]
Old Mar 28, 2002 | 08:58 AM
DutchITR1689's Avatar
Check ALL fuses!!!
Old Mar 28, 2002 | 09:01 AM
E46M3CB's Avatar
Default Re: Help!!! Car won;t start!!! (EuroITR1689)
done that all fuses are good 2 go
MPH's Avatar
MPH
New User
"how do i check if the fuel pump is running what about the injectors"
Fuel pressure gauge
"how do i check if the starter teeth is grabbing the flywheel"
Don't know. Maybe pull the starter and examine the teeth.
[Modified by MPH, 1:02 PM 3/28/2002]
Old Mar 28, 2002 | 09:02 AM
Chris's Avatar
If the crankshaft is turning, then the teeth are grabbing.
If the fuel pump is working you will hear a mechanical "buzzing" for the first 5 sec once the key is put to "ON" (but dont turn it all the way to start) and after that there should be a high pitched whistle sound (once the motor is runniing)...real hard to hear with interior in, but DAMN is it loud without it!!
It would seem to be fuel or spark for sure.. maybe pull an injector out and crank it..will it squirt out fuel?
Old Mar 28, 2002 | 09:05 AM
Why not?
Old Mar 28, 2002 | 09:08 AM
ak-s2000's Avatar
If your getting fuel to the fuel filter the pump is working. Since you are getting a spark at the plugs then its a fuel problem, no gas getting to the spark. Try another fuel filter, that one could be defective. What about any fuel pressure regulator being used. Did you crimp the fuel line when you remove the old fuel filter and forgot to uncrimp it? I would go back and look over everything you did related to the fuel.
