Oil Pump?
Old Feb 20, 2006 | 07:31 AM
jman86's Avatar
Default Oil Pump?
Ok guys ive been reading alot around the forums and online...and i keep seeing people using Prodrive oil pump gears...Where are these gears coming from...i cant find anywhere to buy one...ive searched ebay...google...yahoo..and cant find where to buy one for an LS block...Im currently building an LS/VTEC turbo motor and i want to upgrade the oil pump or something...
any other suggestions on the upgrading the oil pump would be appriciated...
Thanks, JMAN
Old Feb 20, 2006 | 01:48 PM
jman86's Avatar
Default Re: Oil Pump? (jman86)
Anyone?
Old Feb 20, 2006 | 01:49 PM
bks84's Avatar
Loved
i tried doing a quick search, but found nothing man. this sucks...
Old Feb 20, 2006 | 03:07 PM
jman86's Avatar
Default Re: (4sd4dr)
Yeah i did alot of searching...i cant even find the prodrive site where it says nething about oil pump gears..
Old Feb 22, 2006 | 06:01 AM
jman86's Avatar
Default Re: (jman86)
Old Feb 22, 2006 | 06:27 AM
DC2 Mang's Avatar
toda makes oilpump gears, or you can just go with an itr/gsr oil pump and it will work fine on your lsvtec
Old Feb 22, 2006 | 07:20 AM
bks84's Avatar
Loved
Default Re: Oil Pump? (JDMdc2lsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2lsVtec &raquo;</TD></TR><TR><TD CLASS="quote">toda makes oilpump gears, or you can just go with an itr/gsr oil pump and it will work fine on your lsvtec</TD></TR></TABLE>
they are probably cheaper than the Toda/Pro Drive units too. I know I paid 83 shipped for my ITR pump.
Old Feb 22, 2006 | 11:22 AM
DC2 Mang's Avatar
Default Re: Oil Pump? (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote"> I paid 83 shipped for my ITR pump.</TD></TR></TABLE>
thats the right way to go you can never go wrong with oem parts
Old Feb 22, 2006 | 05:05 PM
jman86's Avatar
Will the oem oilpump be ok for a built ls/vtec turbo setup...
Thanks, JMAN
Old Feb 22, 2006 | 05:15 PM
DC2 Mang's Avatar
the ITR oem pump will work fine for your lsvtec turbo
if you want to go all out you can get an external dry sump oil system
Old Feb 22, 2006 | 05:26 PM
loudassVTEC's Avatar
Or you could get a Spoon oil pump. It is a stock Type R OEM housing, with an upgraded gear. Should be way more than enough. A stock Type R oil pump will be enough for your setup, unless you are spinning like 10,000+ RPM, which on a turbo street motor, is pointless, unless you are running a dump truck turbo, and it doesn't spool until 7000rpm.
Old Feb 22, 2006 | 05:46 PM
bks84's Avatar
Loved
Default Re: Oil Pump? (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Or you could get a Spoon oil pump. It is a stock Type R OEM housing, with an upgraded gear. Should be way more than enough. A stock Type R oil pump will be enough for your setup, unless you are spinning like 10,000+ RPM, which on a turbo street motor, is pointless, unless you are running a dump truck turbo, and it doesn't spool until 7000rpm.</TD></TR></TABLE>
That Spoon Oil Pump is $300 from modacar, can you justify the need for the oil pump other than saying its mad tyte jdm?
Here's a link if youre interested in blowing $300, IMO the Stock ITR unit will suffice for street use.
Old Feb 22, 2006 | 05:50 PM
I didn't recommend it, I was just saying, if he's worried about a stock type r pump not being enough, he could go this route. A stock Type R pump will be just fine.
Old Feb 22, 2006 | 07:14 PM
bks84's Avatar
Loved
IMO, if a stock ITR pump isnt enough then, expletive it convert to a external pump dry sump kit.
phyzJunkieCivic
Aug 24, 2006 10:27 PM
InfamousRS
May 1, 2002 08:12 PM
