Buildup Opinions ...
building the bottom end on my itr and could use some helpful opinions as to what to do.. Id like to be making some nice na power..
current setup:
AEM CAI
AEM pulley kit
AEM Cam Gears
JDM 4-1 w/heat shields + DEI wrap
Adrian Teo custom cat
Apex'i N1 catback
B&M fuel meter
B&M adj. FPR
Crower 63402 RR cams
Crower dual springs + Titanium retainers
Hondata stage 2
RC 440cc injectors
Toda timing belt
MSD 8.5mm wires
Hondata Intake Manifold Gasket
Stock ITR bottom end
Stock ITR Tranny
Im redoing the bottom end, well really was just planning on geting it honed and throw a nice set of pistons and rods to make some nice power.. I dont plan to sleeve it, but id like to get some suggest. on which pistons and rods to get and what comp. and why... thanks for ur help.. sorry old jdm teg was boosted, goin na now
Modified by klubhed1 at 10:42 AM 2/20/2006
current setup:
AEM CAI
AEM pulley kit
AEM Cam Gears
Apex'i N1 catback
B&M fuel meter
B&M adj. FPR
Hondata stage 2
RC 440cc injectors
Toda timing belt
MSD 8.5mm wires
Stock ITR Tranny
there are a million options. Ill offer some suggestions.
get some higher compression oversized pistons (CTR or custom)
thin headgasket
port/polish head
quality header
valve job, maybe oversize valves
big cams, better valve springs
big injectors (440s probably sufficient)
tuning tuning and more tuning
should be good for over 200whp, probably closer to 210-215ish give or take
thin headgasket
port/polish head
quality header
from what you have listed it sounds like a bad *** setup but my only suggestion is for some decent "nice na power.." i would look into different cams like (toda, or jun), maybe some valves, and maybe getting your head PnP'ed. now the issue about rods and pistons i think it is more of a personal preference (on a side note manely makes some bad *** rods). from what i have seen in the All motor forum head work is a very popular modification to do for NA build-ups and it yeilds some pretty decent gain
good luck
good luck
the cams are = to jun3 ... and i was planning on getting valves also, but thats all the head work i planned on doing for the moment atleast.. id like to concentrate on the bottom end for now..
stock rods are fine as long are you are revving the **** out of them. keep the stock R limiter (if we are talking about an R here). might wanna polish, balance the crank, use ARP rod and head bolts.
Nice N/A power and work to the bottom end....
Sleeve the block, bore it to 84-85mm or if your feeling froggy, bore it to 86mm.
Run high compression pistons and appropriate rods.
There is actually a lot of useful information in the all motor section. I'm in there all the time reading up.
ok guys.. well, i decided im gona sell my spare itr shortblock everything minus pistons and rods.. use that money and sleeve the original c5 block.. ok now question is... who should get it sleeved by? i was planning on benson. and not sure what to bore it to.. any suggestions?? id like to make some nice power.. lmk thanks
btw if anyone lookin for an itr shortblock check my sig.. thanks
I had my block sleeved by Benson via Earl Laskey, and I could not be happier. Turnaround time was fast; 2.5 weeks for shipping, all machine work, assembly, and return shipping. Ask people how long it takes to get a block back from AEBS or GE.
With the cams you're running, I'd recommend somewhere in the 12.5:1 range. That would be ideal, because you can still run aggressive ignition timing on pump gas.
A little info on my build:
https://honda-tech.com/zerothread?id=1523438
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klubhed1 »</TD></TR><TR><TD CLASS="quote">how much did that run you...</TD></TR></TABLE>
Breakdown...
$950 Benson Sleeves install/cylinder hone
$150 Benson balanced/micropolished crank
$495 CP Pistons and rings
$365 Eagle Rods
$100 ACL bearings
$250 OEM oil/water pump
$50 Gasket/seal set
$490 Blue print and assembly
$125 USA (lower 48) delivery
$2975...Total
Breakdown...
$365 Eagle Rods
$100 ACL bearings
$50 Gasket/seal set
$2975...Total
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">
Breakdown...
$365 Eagle Rods
$100 ACL bearings
$50 Gasket/seal set
$2975...Total</TD></TR></TABLE>
Very nice setup. I am researching a very very similar setup.
Breakdown...
$365 Eagle Rods
$100 ACL bearings
$50 Gasket/seal set
$100 ACL bearings
How do you "blueprint" with ACL bearings which are all the same size?
$100 ACL bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith »</TD></TR><TR><TD CLASS="quote">How do you "blueprint" with ACL bearings which are all the same size?</TD></TR></TABLE>
That was a cut and paste from Earl's price breakdown from last year when I built the motor. Ask Earl.
I'm going to assume he measures piston/wall clearance, ring gap, and makes sure that the bearings are 'within' spec, even though they are one-size-fits-all.
I'm going to assume he measures piston/wall clearance, ring gap, and makes sure that the bearings are 'within' spec, even though they are one-size-fits-all.</TD></TR></TABLE>
Gotcha... regardless that is a great price. I don't know how they can do all that for under $500 and stay in business!
builtprelude
Nov 24, 2003 05:23 PM
