50mph to 75mph times?
Just wonder if anyone has done this test. In metric terms its 80km to 120km, and im pretty sure Apexi RSM has this function.
What's your set up and what times have you run?
70-90 mph seems to work better for the DSM guys. 50-70mph will likely put you right in the middle of a shift. Going 70-90 will likely be in third gear to help keep traction and likely high enough in the RPM range that you will have full boost.
70-90 times -> 1.8 seconds
It works pretty well to get you in the right tuning ball park while on the street. With tuning changes, I have seen .2-.3 second improvements at times.
kameleon23
Apr 26, 2006 10:47 AM
