help on h22a and type s!!!!!!
Old Feb 19, 2006 | 10:07 PM
ej1_lsvtec's Avatar
Default help on h22a and type s!!!!!!
how can i tell the diffrence on h22a cams and piston and type s any castings on them? And would the type s pistons work on regular h22a rods, or should i get type s rods? any help is apriciated. thanks bump if viewed
Old Feb 20, 2006 | 06:06 AM
ej1_lsvtec's Avatar
Default Re: help on h22a and type s!!!!!! (ej1_lsvtec)
bump
Old Feb 20, 2006 | 06:42 AM
92hondalude's Avatar
type s pistons wont work on h22a rods. i heard storys about them being modded to work.
You could buy h22a4 rods and they would work
Old Feb 20, 2006 | 07:15 AM
veganej's Avatar
Default Re: help on h22a and type s!!!!!! (92hondalude)
as far as i know the only true way to tell the difference is in the measurements.
Old Feb 20, 2006 | 07:35 AM
mgags7's Avatar
just take a micrometer to the cam lobes and you will know the difference....
as far as pistons/rods:
type s pistons use floating wrist pins
obd1 jdm h22a and us h22a1 use a solid wrist pin, and you can have the rod re-bushed to use floating pins
us h22a4 and obd2 jdm h22a use floating, and they will work as is (are)....
Old Feb 21, 2006 | 08:42 PM
ej1_lsvtec's Avatar
Default Re: (mgags7)
iamalex1212
Sep 1, 2008 09:01 PM
spooledhonda
Dec 4, 2006 05:07 PM
candymanjl
May 29, 2006 08:09 PM
aeolus
Dec 27, 2003 03:04 AM
