99 civic ex brakes on my 94 del sol?
Old Feb 19, 2006 | 09:55 PM
b16_sol_707's Avatar
Default 99 civic ex brakes on my 94 del sol?
I have a wrecked 99 civic ex, What would I need to do to put the front rotors on my 1994 Del sol?
Old Feb 20, 2006 | 06:49 AM
EK-Chris's Avatar
Default Re: 99 civic ex brakes on my 94 del sol? (feathers321)
Just the rotors, or the entire brake assembly? Either way - easiest way is to disconnect the entire steering knuckle and bolt it to your Del Sol. Its only 4 bolts and it comes off...
Old Feb 20, 2006 | 01:01 PM
Default Re: 99 civic ex brakes on my 94 del sol? (EK-Chris)
I was going to try to use just the rotors, maybe the caliper bracket. The civic has larger rotors than my Sol. Wouldn't I run into problems if I swapped the whole brake assembly since the Civic has ABS?
Old Feb 20, 2006 | 08:10 PM
EK-Chris's Avatar
Just because it has ABS doesnt mean you have to use it. Its just a sensor, my Integra steering knuckles had it, its just not being used (ABS). Its a lot easier and faster to swap the entire steering knuckle.
Look at my setup:
1) 94 Integra knuckles
2) Type R Calipers, w/ stock Pads *Calipers were cut 4 mm for clearance
3) 11.1 Fastbrakes Brembo slotted/drilled rotors
All OEM honda parts, you just have to know the right combinations...
Old Feb 20, 2006 | 09:08 PM
Thanks, I'll try that next weekend
robbys89
10
May 16, 2010 09:20 AM
delsolnewkid
Mar 13, 2006 07:20 AM
dnbruut
10
Oct 11, 2005 10:10 AM
jdmbb6
Jul 19, 2005 07:35 AM
duh blacksheep
12
Apr 26, 2005 07:53 AM
