using timing belt cover with Honda N1 pulley ?
Old Feb 19, 2006 | 09:54 PM
99teggsr's Avatar
Default using timing belt cover with Honda N1 pulley ?
Is it possible ? I am test fitting mine now, and it seems that I will have to dremel out the lower timing belt cover or just ditch the belt cover completely
Also, is there an inner lower timing belt cover ? I only have 3 pieces, is this right ?
This pulley
Old Feb 19, 2006 | 10:19 PM
wob's Avatar
wob
hmm if it wont fit just dremel it i guess.. coz leaving it off completely is a disaster waiting to happen
comteg396's Avatar
Default Re: using timing belt cover with Honda N1 pulley ? (99teggsr)
fits fine with no mod to lower timing belt cover. you will need a new belt. shorter one
Old Feb 20, 2006 | 12:41 AM
99teggsr's Avatar
Default Re: using timing belt cover with Honda N1 pulley ? (com-teg)
Got it figured out, ive got an ITR oil pump on my c1 block, I have to use the ITR lower timing belt cover.
Old Feb 20, 2006 | 05:03 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr &raquo;</TD></TR><TR><TD CLASS="quote">Got it figured out, ive got an ITR oil pump on my c1 block, I have to use the ITR lower timing belt cover.</TD></TR></TABLE>
itr oil pump = gsr oil pump.
Old Feb 20, 2006 | 07:00 AM
99teggsr's Avatar
Default Re: using timing belt cover with Honda N1 pulley ? (LSvtec03)
ITR part # : 15100-P72-A01
GSR part# : 15100-PR3-024
So, They may have the same guts, but the outter housing is different because the lower timing belt cover for a gsr will not fit a itr pump.
Old Feb 20, 2006 | 07:03 AM
99teggsr's Avatar
ITR lower timing belt cover : 11810-P72-A00
GSR lower timing belt cover: 11810-PR3-010
Old Feb 20, 2006 | 01:11 PM
LSvtec03's Avatar
sorry dude, but you're mistaken.
itr oil pump - 15100-P72-A01
gsr oil pump - 15100-P72-A01
itr lower cover - 11810-P72-A00
gsr lower cover - 11810-P72-A00
(sourced from http://www.acuraparts247.com)
not trying to argue, just saying if you're hoping this will solve your problem, you're barking up the wrong tree. please trust me, the itr and gsr timing belt covers are identical. in fact, they are even the same on b16s. only LS covers differ from the vtec ones.
edit: did some more looking. the part number you listed is for 90-95 integras. but as you have a 99 gsr, it is still the same part as an itr.
Modified by LSvtec03 at 6:25 PM 2/20/2006
Old Feb 21, 2006 | 04:26 AM
99teggsr's Avatar
How come my lower timing belt cover does not fit then ? It leaves a large 1" gap between the oil pump and the timing belt cover.
Old Feb 21, 2006 | 05:06 AM
LSvtec03's Avatar
i dunno, but both acuraparts247.com and acuraautomotiveparts.org show that the gsr and itr have the same part.
Old Feb 22, 2006 | 08:49 PM
99teggsr's Avatar
Figured it out, in 98 the ITR/GSR oil pump changed, there is a spot for a crank sensor on it.
I have a 94 timing belt cover, but a 98+ oil pump. and thats why it wont fit correctly.
errusieck
Apr 10, 2010 09:41 PM
88da3
Apr 12, 2005 11:44 AM
85mm LS VTEC
Aug 4, 2004 02:18 PM
MisterB
Jan 24, 2003 06:37 PM
webhitch
Nov 14, 2002 08:01 AM
