new front crossmember
Old Mar 27, 2002 | 06:41 PM
XoSiKCiViCoX's Avatar
Default new front crossmember
Just saw an ad somewhere, in one of the mag's that someone (how do you like my specific's?) makes a front crossmember that free's up something like 8 inches for room for a turbo....
Has anyone researched this... if so i would like to know the info...
thanks
Old Mar 27, 2002 | 06:42 PM
EP3_05's Avatar
Default Re: new front crossmember (XoSiKCiViCoX)
Might be the Z10 unit or place racing or MB. I would venture a guess to say that it is the Z10 front crossmember. Check them out at http://www.z10eng.com
Old Mar 27, 2002 | 06:47 PM
newspeedR's Avatar
The bar you are referring to is from Place Racing
Hit them up and see what its about, but it basically moves the motor so you have more room for AC, turbo, radiator or anything else...
Old Mar 27, 2002 | 06:50 PM
EP3_05's Avatar
Default Re: new front crossmember (newspeedR)
The motor doesn't move unless the position of the motor mounts change. What the crossmembers do is free up more room for using a half sized radiator and for a larger downpipe or header.
Old Mar 27, 2002 | 06:52 PM
89 CRX SI's Avatar
Default Re: new front crossmember (91civic)
Ya i read that two looks nice. It was in Honda Tuning mag.
Old Mar 27, 2002 | 07:34 PM
Tbone's Avatar
https://honda-tech.com/zerothread?id=152810
Old Mar 27, 2002 | 07:40 PM
Mugen Dom's Avatar
Default Re: new front crossmember (Tbone)
place racing is junk it breaks Z10 is quality ****
Old Mar 28, 2002 | 07:47 AM
Bnjmn's Avatar
Default Re: new front crossmember (jdmB18hatch)
While we are at it- has anyone ever used the MB crossmember? It is $200! cheaper than the Z10 and uses more expensive chromemoly for the crossmember as opposed to Z10s steel.
Thanks
Ben
Old Mar 28, 2002 | 08:15 AM
89civic1.8T's Avatar
Default Re: new front crossmember (Bnjmn)
I would like to know too. I am saving up for a Z10 but is the other one is strong and works well I may get that instead. The one thing I wonder about is why it says on there site that crossmeber is for off road only (racing)? As long as it isn't as shitty as place racing peice of junk I may be up for it.
Old Mar 28, 2002 | 09:30 PM
Bnjmn's Avatar
Default Re: new front crossmember (89civic1.8T)
I called Manta Ray (which sells the MB) and they didn't have much constructive to say about the difference between the MB and the Z10. They said it "didn't compare" but the only difference that I heard was the steel vs. chromemoly. All that means to me is that I have to get somebody to TIG weld in my front mount as opposed to me MIG welding it in.
I called MBs #, but the one they have listed on their site has been disconnected.
Ben
dingusjt
Nov 9, 2003 05:36 PM
ScottEK
Aug 8, 2003 06:28 AM
BigBlockCRX
Apr 9, 2003 12:31 AM
Eggman
Nov 5, 2002 01:00 PM
