I'm an idiot & need help geting an axel back in
Old Feb 19, 2006 | 03:33 PM
black_bb1's Avatar
Default I'm an idiot & need help geting an axel back in
so, im installing a set of coilovers on my prelude and like an idiot i left the wheel on my front passenger side while dismanteling the suspension, and when it droped it poped the axel out partially, is this something i can just pop it back in or did i break a clamp or bracket of somesort inside?
Old Feb 19, 2006 | 03:44 PM
DVS Luder's Avatar
Default Re: I'm an idiot & need help geting an axel back in (black_bb1)
not sure if this is the right way but my friend did the same **** haha. he used a jack to compress the arm up which forced the axle to slide in but at the same time twisting it around. i dunno if thats the proper way tho but it did work tho.
Old Feb 19, 2006 | 03:45 PM
p nut's Avatar
Did it pop out of the tranny side or from the wheel? I guess either way, you just have to pop it back in. And I'm sure you didn't break anything, since they just pop in and out, but check the tranny seal to see if it's torn. And make sure you add more MTF, since I'm sure plenty has leaked out.
Old Feb 19, 2006 | 03:56 PM
black_bb1's Avatar
Default Re: (P Nut)
it poped out of the tranny side and the seal is still intact, it only partially poped out going to give the jack a try
Old Feb 19, 2006 | 05:01 PM
UK_prelude VTEC's Avatar
Default Re: (black_bb1)
You'll find it alot easier if you take the boot off the joint. You need to be careful because the 3 donut bearings on the shaft side can move inwards towards the shaft to the point where they will not slide back into the joint, and you may cause damage trying to force it. When lined up it should slide in with very little effort.
Best way is to jack the assembly up until it's level, line it up, then use your fingers to slide the donut bearings outwards until they line up with the slots in the joint. It will be very messy, but is better than ******* the joint up!
A picture would make this make alot more sense, but I can't find one!!
akylem
Nov 21, 2008 06:11 PM
Dann6968
Jan 9, 2008 12:47 PM
undertheradar
12
Feb 15, 2006 02:01 PM
trulyshavedintegra
Apr 6, 2005 12:59 PM
josh green
Aug 3, 2004 07:51 PM
