Water in trunk + Taillight Fuse Blown
Old Feb 19, 2006 | 03:10 PM
vinuneuro's Avatar
Default Water in trunk + Taillight Fuse Blown
After searching, it seems like a number of 5g owners have had water in the trunk.
My taillight fuse is blown and there is a little water getting into the trunk area. Logic suggests that it's leaking from the taillight seal. But how is it getting in the taillight, shorting it out the circuit and then coming into the trunk? How do I fix this....how do I seal the taillight?
Old Feb 19, 2006 | 03:16 PM
Loppy's Avatar
you have oem trunk lid? cf trunk lid? i've heard alot people people with VIS trunks have water leaking through the key hole.
Old Feb 19, 2006 | 03:46 PM
DVS Luder's Avatar
Default Re: Water in trunk + Taillight Fuse Blown (vinuneuro)
i got the same exact problem but only on one side, damn water is in my left side taillight.
Old Feb 19, 2006 | 03:57 PM
vinuneuro's Avatar
Default Re: (Loppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loppy &raquo;</TD></TR><TR><TD CLASS="quote">you have oem trunk lid? cf trunk lid? i've heard alot people people with VIS trunks have water leaking through the key hole.</TD></TR></TABLE>
Sotck trunk
Old Feb 19, 2006 | 04:02 PM
lude98SH's Avatar
Default Re: (vinuneuro)
I had the same problem it seemed to be getting in my taillights. Put some tape on the area of the light that meets the back of the car, see if that helps. If you dont see any water than you know thats where the water was getting in. Its ghetto but will cheaply allow u to locate the problem.
Old Feb 19, 2006 | 04:55 PM
ckyskater733's Avatar
silicone the seals around the trunk. if you need to pin point it, spray water on your car and see if u can find where its leaking.
this is a problem in i think all older hondas.
Old Feb 19, 2006 | 07:13 PM
lude98SH's Avatar
Default Re: (ckyskater733)
Silicone around the lights or in the actual trunk ?
Old Feb 20, 2006 | 10:57 PM
AdReNaLiN's Avatar
Pull your light out - silicone around where it meets the body of the car - there should be the remaining factory seal already there to guide you as to where to put your silicone.
Worked wonders when my trunk leaked.
Old Feb 21, 2006 | 04:30 AM
brolli's Avatar
Default Re: (AdReNaLiN)
take out the carpet, hop in the trunk, and have ur buddy run it through the automated car wash. bring a flashlight
Old Feb 28, 2006 | 09:57 PM
kojiro21's Avatar
Default Re: (brolli)
haha, do it!
but yeah im having same problem with my ek. water is leaking through passenger door too, i saw water trails on my speaker grille for the door. is it the rubber door lining/seal?
Daniel Morgan
Aug 16, 2019 02:34 PM
Prudz_lude
Feb 8, 2016 11:19 AM
beat
Jun 11, 2014 11:04 AM
tcontesh
May 2, 2006 07:08 AM
nEoMuGen
Aug 12, 2001 06:21 AM
