Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools
Old Feb 19, 2006 | 11:17 AM
Tbone's Avatar
Default Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools
For Sale .
My Jenvey ITB's are up for grabs , these are the ones I have run on my car for the last year. These are currently setup for a p72 head but can be set back up for pr-3 if the buyer needs me too. I will sell it with both manifold sections for both heads for an extra 300.00 .
My best power #'s were 268 whp on a stock gsr crank with 85mm bore. 12.5 cr.
These have custom horns that are setup for a broad powerband.
I'll include a custom vacuum can,Fuel Rail, fuel lines, TPS sensor,and throttle cable.
I have flow bench results of these compared to and Endyn Air manifold, Jg edlebrock,Skunk 2 and bare head.
Check the bottom for new stuff daily
Snapon compression tester new in the box. Part # mt308kb
This wa used 1 time..The only drawback is that the gauge is only good to 250 psi.. My allmotor stuff goes up to 300 so this wont work for me anymore.
Ok and 1 last non honda item..
I have a brand new in the box Magnaflow dual exhaust for a 2000-2003 extended cab Dodge Dakota.. Magnaflow Model 15736.
This sells for 642.72 new...
Mine is still new except some minor scratches in some of the pipes from test fitting iit on my truck .. didnt workout since I have a quad cab with a lift..
I'll let this go insanly cheap....375.00
Email is tbone327@***.net
paypal verified
postal money orders accepted..
I'm always up for trades on some of it..
Update.
I have abrand new in box set of Eagle .137log LS vtec rod's
These are used so that you can have the extra displacement of the ls crank all while still using the factory rod stroke ratio of an Integra type r.
300.00 or best offer
Last one here for tonite is a set of supertech .5mm intake overesize high cr flatface valves with a set Rocket motorsports flat face 2 piece racing flat valves.
Accepting reasonable offers on all 16 high cr valves,
Modified by Tbone at 2:08 PM 5/17/2006
Modified by Tbone at 2:11 PM 5/17/2006
Modified by Tbone at 2:12 PM 5/17/2006
Modified by Tbone at 4:06 AM 5/27/2006
Old Feb 19, 2006 | 07:20 PM
doubleA's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (Tbone)
bump for that sweet obd0 test harness. Id make an offer but im afraid of lowballing
Old Feb 19, 2006 | 07:28 PM
swaytec360's Avatar
bump for good seller and all motor god
Old Feb 20, 2006 | 03:08 AM
Tbone's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (doubleA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleA &raquo;</TD></TR><TR><TD CLASS="quote">bump for that sweet obd0 test harness. Id make an offer but im afraid of lowballing </TD></TR></TABLE>
High bidder is at 150.00 right now on it..
Old Feb 21, 2006 | 04:23 AM
BERT-O's Avatar
Old Feb 21, 2006 | 06:16 PM
ICeDoUt's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (BERT-O)
pm'd you
Old Feb 24, 2006 | 03:23 AM
Turbocivic94's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (ICeDoUt)
bump
Old Feb 24, 2006 | 06:01 PM
Nick M's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (Turbocivic94)
bump for tbone
buy his stuff, super reliable seller
Old Feb 25, 2006 | 04:13 AM
BERT-O's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (Nick M)
Old Feb 28, 2006 | 04:55 AM
TodaCivic's Avatar
Bump ...you got Pm.
Old Mar 4, 2006 | 12:40 AM
murtnabila's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (TodaCivic)
Old Mar 4, 2006 | 03:43 AM
JohnnieChimpo's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (murtnabila)
I want those rods.
Old Mar 4, 2006 | 04:28 AM
jsnm's Avatar
sent you a pm.
Old Mar 5, 2006 | 08:04 PM
Tbone's Avatar
Default Re: (jsnm)
Dist and cat and harness are sold..
Old Mar 13, 2006 | 02:31 PM
Tbone's Avatar
Default Re: (Tbone)
Crower cams
rocket springs
itr springs
SOLD
Old May 3, 2006 | 02:46 PM
Ruthless DC2's Avatar
From: Jacksonville, Florida, United States of America
Default Re: (Tbone)
how much for the comp. tester. around what comp does it work up to(as far as psi reads)?
Old May 17, 2006 | 10:12 AM
Tbone's Avatar
upity
Old May 19, 2006 | 05:39 AM
S9i1R's Avatar
bump!
Old May 22, 2006 | 06:51 AM
Tbone's Avatar
Default Re: (Ruthless DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruthless DC2 &raquo;</TD></TR><TR><TD CLASS="quote">how much for the comp. tester. around what comp does it work up to(as far as psi reads)?</TD></TR></TABLE>
it goes up to 250.. make offer
Old May 24, 2006 | 12:54 AM
racerboyb18c1's Avatar
Default Re: (Tbone)
bump for ITBS i wish i could own some one buy em thats a steal
Old Jun 1, 2006 | 11:19 AM
drift4jesus's Avatar
Default Re: (racerboyb18c1)
interested in the valves and rods. isn't the R/S ratio still slightly less than a itr/gsr? itr/gsr=1.58 ls/b20=1.54 +.137w/ ls crank =1.56
Old Jul 20, 2006 | 08:00 AM
jeremy.'s Avatar
pm'd
GirlieRacer7o2
Mar 3, 2007 06:25 AM
paulzy
Aug 20, 2006 06:03 PM
Tbone
Feb 19, 2006 02:35 PM
DSLHONDA
Oct 30, 2004 09:57 AM
B16GSR
Feb 1, 2003 09:04 PM
