Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools
Old Feb 19, 2006 | 11:17 AM
Tbone's Avatar
Default Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools
Check the bottom for new stuff daily
I have here a limited production Racing Distributor that I did dyno testing on for the manufacturer. These aren't available to the public yet so you guys probably haven't seen one..
Features that make this unit special is that not only does it come with a external coil mounted in its own heat sink, but also an EXTERNAL IGNITER unit moved out to the heat sink as well.. This allows the igniter to cool rapidly instead of heat-soaking in the dist like an oem unit..The other nice thing is that it comes totally pre wired and is 100% plug and play with an obd-1 harness..You only need to connect 1 wire to a ground source.. It will install in 1/4 of the the time of a full msd ignition setup..
I dynod this up against my full msd ignition setup which consisted of ..Msd 6al ignition, MSD blaster ss external coil, Msd pro cap and coil wire.. (just keep in mind of how much wiring involved with setting up the whole msd setup)
This custom race dist/ignition setup was dynod back to back with several runs on each. This unit was down only 1whp over the full msd setup.. I was shocked since it does look like a show car item with the chrome housing and blue cap.lol.
This unit sells for 550.00.. I'm accepting best offers.
Partial trades towards a twin disk hydro tranny clutch..(or single Tilton). Accepted
The blue line is the full MSD setup and the red line is this custom setup
Dont be afraid to make a reasonable offer. I need this stuff gone so I'll be very fair..
New universal carsound 2.5 in cat converter..
Crower 63401 cams, used for less then 10 miles.
These are slightly more aggressive then a civic type r cam.. I'll include a brand new set of integra type r inner valve springs with these cams so you can just pop them in and run them.. 350.00 with springs 400.00 with the springs and a set of adjustable AEM cam gears.
Snapon compression tester new in the box. Part # mt308kb
This wa used 1 time..The only drawback is that the gauge is only good to 250 psi.. My allmotor stuff goes up to 300 so this wont work for me anymore.
Finally my og wheels.
These are real deal Racing Hart cp035's that have been powdercoated black.They still have the original bronze under so you could strip off the powder coat if you want them gold. These are the lightest 15 in forged wheel on the market to my knowledge..They are only 6.5-7lbs if i remember correctly..
I'll throw in the tires for free. Up front are bfg drag radials 205x50x15 , the tread patteren is worn down pretty good on these BUT they still grab as good if not better then new. In the rear are potenza RE010's with 88% tread left and they are still like new. 1 wheel has a few chips in the black powdercoat so you can see the gold in those spots..These are used and not ijn any way showcar shape..
They are forged racing wheels and thats what they were used for..lol
I'll let these go for the first 850.00.. these rims alone are over 400.00 a piece new..The rims were not cleaned at all for the pics, so they are very dirty..lol
They are 7lbs each if I remember correctly.
Ok and 1 last non honda item..
I have a brand new in the box Magnaflow dual exhaust for a 2000-2003 extended cab Dodge Dakota.. Magnaflow Model 15736.
This sells for 642.72 new...
Mine is still new except some minor scratches in some of the pipes from test fitting iit on my truck .. didnt workout since I have a quad cab with a lift..
I'll let this go insanly cheap....375.00
Email is tbone327@***.net
paypal verified
postal money orders accepted..
I'm always up for trades on some of it..
Update.
I have abrand new in box set of Eagle .137log LS vtec rod's
These are used so that you can have the extra displacement of the ls crank all while still using the factory rod stroke ratio of an Integra type r.
300.00 or best offer
Up for grabs here is a set of Rocket motorsports gen 1 iners, these are perfect for boosted cars that want to rev much higher then stock.. Best offer
Last one here for tonite is a set of supertech .5mm intake overesize high cr flatface valves with a set Rocket motorsports flat face 2 piece racing flat valves.
Accepting reasonable offers on all 16 high cr valves,
Modified by Tbone at 7:14 AM 2/20/2006
Modified by Tbone at 5:12 PM 2/20/2006
Modified by Tbone at 10:31 PM 2/20/2006
Old Feb 24, 2006 | 03:24 AM
Turbocivic94's Avatar
Default Re: Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools (Tbone)
buy buy
Xtreme_Cause
18
Jun 22, 2020 08:27 AM
CANARYKID
Northern California (Sales)
Apr 11, 2013 01:03 PM
Turbo Wax
Nov 5, 2009 03:05 PM
seen4ever
Jun 20, 2005 05:56 PM
