maintance on... 106k
Old Feb 19, 2006 | 10:41 AM
sony224422's Avatar
Default maintance on... 106k
what else should i do at 106k
so far i have changed the tranny fluid (at)
changed plugs
cleaned the air filter
changed the oil
rotated tires
checked the brakes
is there anything else i should do. shes running fine so im just doing preventive maintance. I know i have to get my t-belt done soon, but is there anything else?
Old Feb 19, 2006 | 12:29 PM
YeuEmMaiMai's Avatar
Default Re: maintance on... 106k (sony224422)
if you haven't done your t-belt yet, you better do it as well
Old Feb 19, 2006 | 08:14 PM
sony224422's Avatar
Default Re: maintance on... 106k (YeuEmMaiMai)
anything else. i wanna keep her running strong and well.
Old Feb 19, 2006 | 08:26 PM
basically you just need to inspect everything. IF you have not changed your coolant in a long time it might be a good idea to do so.
Inspect your CV joints
Rubber suspension parts
change brake fluid if it has not been done in a while
adjust parking brake
change oil and filter
change PS fluid if not done in a while
change tranny fluid if it has not been done in the last 30K (I do mine once a year)
apply some silicon grease to your weather stripping and window tracks
check your ball joints if your car shakes and it is alligned properly
check and change air filter if needed
check and change PCV valve if needed
valve adjustment if it has not been done in the last 30K (replace valve cover gasket grommets and tube seals when you do this)
Old Feb 19, 2006 | 08:38 PM
sony224422's Avatar
oh boy haha. i gotta do some moreeee. thanks though.
Old Feb 19, 2006 | 08:39 PM
sony224422's Avatar
is adjusting the valves completely different than the timing belt, or when i do the timing belt will the valves be adjusted..
Old Feb 19, 2006 | 08:53 PM
timing belt should be changed first and then once your timing is back in spec, then adjust the valves when the engine is cold.
Old Feb 20, 2006 | 02:06 PM
sony224422's Avatar
is there a right up on how to adjust the valves.. or should i have a shop do it. I won't lie, i have no idea how to do it, and i have to get a manual. But is it hard to do?
Old Feb 20, 2006 | 02:50 PM
i let my local honda dealer do it and everything including replacement seals, grommets, and tube seals was $116 plus tax
Old Feb 20, 2006 | 03:54 PM
sony224422's Avatar
sounds reasonable, but i think my shop will want alot more, seeing they wanted $219 for atf change.
nukem384
Mar 16, 2010 07:20 AM
Convert
13
Feb 28, 2008 12:17 PM
hometheaterman
Jan 30, 2008 03:44 PM
RUBZERK
Sep 18, 2003 09:01 AM
InfamousRS
Oct 5, 2001 09:55 PM
