Suspension & Brakes Theory, alignment, spring rates....
TEIN SS
Old Feb 19, 2006 | 08:32 AM
1SIKEG6's Avatar
Default TEIN SS
hey im about to purchase a set of tein ss im a noob so wut do the spring ratings mean? the ones im buyin are 8k and 6k i wanna ride nice and low could i do that with this set up with out bottoming out?
Old Feb 19, 2006 | 08:40 AM
PIC Performance's Avatar
Default Re: TEIN SS (1SIKEG6)
K is an abbreviation for kg/mm, which is the measure of spring rate. Multiply by ~53 to get the rate in lbs/in.
8kg/mm means that it will take 8 kilograms on the spring to compress it 1mm. Alternatively, thats something like 447lbs to compress the spring one inch. Higher rates lead to stiffer rides.
How low you can do depends on a few things, but if you don't do anythign silly like slam the car within an inch of its life (where you will see no handling gains anyhow), you should be OK.
JDM Factor
Aug 6, 2006 04:12 PM
donz
Jun 27, 2004 11:45 AM
Paluce
Feb 26, 2003 08:30 AM
