gas pedal sticking
Old Feb 19, 2006 | 04:38 AM
VtecBrian's Avatar
Default gas pedal sticking
Hey I was wondering if there is something i can do to my gas pedal. It sticks when I go to drive when its usually cold. It doesnt stick as in staying down and not coming up, but rather it doesnt want to go down and im afraid i will hit something having to press the pedal to hard and the pedal goin down while trying to get out of parking spots. Is there anything to lubricate? any suggestions? Diagrams?
Old Feb 19, 2006 | 05:23 AM
P_Adams's Avatar
Default Re: gas pedal sticking (VtecBrian)
There are three things which might cause this:
1) Accellerator Pedal Hanger assembly
2) Throttle Cable
3) Throttle Body
To figure out which it is; the process is more an either/or proposition and requires no more the disconnecting the throttle cable from the valve body.
If the bind still exists in the pedal, it's most likely the cable.
If the bind is no longer apparent, the Throttle Body is the culprit.
Sometimes extreme deposits in the throttle bore will cause a binding condition. If not that then the possibility exists the Throttle Body shaft may have worn and the throttle valve sticks now.
P
Old Feb 19, 2006 | 05:36 AM
VtecBrian's Avatar
Default Re: gas pedal sticking (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">There are three things which might cause this:
2) Throttle Cable
3) Throttle Body
P</TD></TR></TABLE>Thanks p for the professional input you provide Im sure you are well appreciated round here.
Would the car being warmed up cause it not to stick, because if it is warmed up it usually doesnt even stick, just at start up not all the time. No problem under normal driving conditions.
Old Feb 19, 2006 | 05:50 AM
P_Adams's Avatar
It very well could; what with the normal expansion and contraction of metals as they heat/cool.
The assembly lube in the cable may be turning to wax (unlikely since you specifically state the throttle returns to idle without problems) or, as I stated elsewhere, the T/B could be horribly crudded up.
This sounds like a project for a cold Saturday (or Sunday) morning.
P
Old Feb 19, 2006 | 07:02 AM
SkRiBLaH's Avatar
might be the stopper screw came loose.. causing the butterfly to close completly and stick.
happend 2 times on 2 differant cars and caused sticking throttle body.
Old Feb 19, 2006 | 08:09 AM
VtecBrian's Avatar
yes P i will keep my eye on the situation. I dont think it warrants tampering with this sunday morning though (10 degrees).
Old Feb 19, 2006 | 08:54 AM
hondadude's Avatar
Your Accord has S.T.D. Sticky Throttle Disease There is a cure however
Get your room mates toothbrush and a can of Berrymans B-12 carb cleaner.
Hold open the throttle plate and scrub out the crud around the throttle plate
Old Feb 19, 2006 | 09:23 AM
P_Adams's Avatar
Default Re: gas pedal sticking (hondadude)
Yes, I have to agree with Hondadude, both a roommates, or a mother-in-laws toothbruxh is best for parts cleaning and fine detail work.
Just don't use them with products like Eagle Mag wheel cleaner or Wheel Brite. It will act to bleach their teeth white when you return it to the brush holder.
P
Old Feb 19, 2006 | 10:10 AM
VtecBrian's Avatar
lol
Old Feb 19, 2006 | 07:51 PM
Superorb's Avatar
i have this same problem on my girlfriend's car but i havent had time to get around to it. it's on the bottom of the "honey do" list...
Old Feb 19, 2006 | 07:57 PM
YeuEmMaiMai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">Your Accord has a S.T.D. Sticky Throttle Disease There is a cure however
There, fixed it for you....you can also use seafoam to clean that up as well. Stuff works magic......
Old Feb 20, 2006 | 06:01 AM
P_Adams's Avatar
Default Re: gas pedal sticking (YeuEmMaiMai)
Hey, isn't that one of former President Clintons Tooth Brushes? The one he used to clean up after the cigar incident?
P
smc1118
May 5, 2014 04:55 AM
85crx509
Sep 3, 2008 11:10 AM
SpeedoKing
Aug 6, 2007 03:09 PM
mr poo
15
Jun 14, 2006 08:09 PM
97civic123
May 5, 2006 10:44 AM
