Ef's with LS swaps what header you using?
Old Feb 19, 2006 | 04:25 AM
chirp the 1-2's Avatar
Default Ef's with LS swaps what header you using?
Put a 0bd0 ls b18 in my 89 dx hatch and bought a 90 ls megan header but had lots of problems with the flange. It isnt the normal doughnut stlye gasket, its more like a thin ring gasket. Anyway bent the b pipe yesterday and am looking for a new header. What header are you guys using and can i use a 94-97 ls header on my 90 ls swap?
thanks in advance
Old Feb 19, 2006 | 04:38 AM
beyondspexj's Avatar
the same header the b16 and b18c1/5 guys lol. try a dc header. what ever b series header you find, it will fit.
Old Feb 19, 2006 | 07:13 AM
4potnick's Avatar
Default Re: (beyondspecs_jamar)
I ran a dcsports jdm header with some eibach sprtlines. Hung way to low. ruined in a matter of days.
Old Feb 19, 2006 | 08:26 AM
kine462's Avatar
Default Re: (4potnick)
I used to use a turbo exhaust manifold
Old Feb 19, 2006 | 09:50 AM
gen2fanatic's Avatar
Default Re: (kine462)
knock-off ITR 1 piece header into custom exhaust (2 3/4" piping, 350z res. and greddy muffler) out of my LS
for a while, i was running the stock LS header, stock single cam downpipe into the stock exhaust with a magnaflow muffler shoved on the end
so you can say i upgraded
Old Feb 20, 2006 | 06:26 AM
TTT
Old Feb 20, 2006 | 06:39 AM
ijjz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar &raquo;</TD></TR><TR><TD CLASS="quote">the same header the b16 and b18c1/5 guys lol. try a dc header. what ever b series header you find, it will fit.</TD></TR></TABLE>
I thought I read once that some are taller then others. Not comparing 41, 421, but a 421 gsr to a 421 ls for example.
BTW, got pics of the megan header?
Old Feb 20, 2006 | 07:26 AM
~Aj~'s Avatar
Default Re: (ijjz)
Megan
Old Feb 20, 2006 | 07:37 AM
b20turboic's Avatar
Default Re: (ijjz)
Vtec headers are taller ... the vtec head is taller than the ls head is so it will hang a little low. Tell you what get a DC Sport LS HEADER OH MY GOSH and it will fit perfecto
Old Feb 20, 2006 | 09:30 AM
That is a 0bd1 header or newer(see 2 02 sensor bungs)
Old Feb 20, 2006 | 09:50 AM
user 72830283's Avatar
Default Re: (chirp the 1-2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chirp the 1-2 &raquo;</TD></TR><TR><TD CLASS="quote">That is a 0bd1 header or newer(see 2 02 sensor bungs)</TD></TR></TABLE>
you mean 1 on the header and 1 on the down-pipe, cuz my obd-0 OEM b16 header also has 2 o2 sensors and they're both on the header itself..!
GreedyPT's Avatar
The ODB0 B16A has two O2 sensors.
Old Feb 20, 2006 | 12:16 PM
Either way if that header is for a ls its 0bd1 or 2. Its not the one i have, nor am i talking about a b16 megan header.
This is it http://cgi.ebay.com/ebaymotors...sting
Old Feb 20, 2006 | 05:50 PM
some companys offer or sell them with 2 holes so they dont have to make 2 versions of the same header. it comes with a plug for those only needing one o2 hole.
yea i forgot the header for vtec b series motors hangs lower.
kenzo42
Nov 5, 2007 09:48 PM
b20civicboi
Apr 20, 2006 02:32 AM
civickiller
Nov 25, 2005 10:53 AM
Type RS
Feb 9, 2003 08:26 AM
fastbrakes
Apr 3, 2002 01:47 PM
