5th gear keeps poping out!?!
ok so my fifth gear keeps poping out on my 2000 b18b engine..the tranny is an RS tranny..same year
and 5th gear just wont stay in unless i keep it in there by me pushing on it in the car..but its still pops out at times..
do i need a new tranny? or is this fixable some how?
thanks
thanks
That was happening to me, then a day later it locked up in first,
I had a hole in my bellhousing from an ear busting off the throwout bearing.
So pretty much, I was doing pretty bad on fluid, and it just seized, but was popping at of 5th first.
Is it harder to shift into gears then normal?
jease thank god i hope im only low on fluid...i though i filled it up right..anyway...ill check that out today..and no the gears arent hard to get in..
its most likely low fluid like someone else already said but i had the same prob and it was cuz the sleeve from 5th to reverse was fu*ked all up. all my syncros were good but the sleeve have a nice bure . so if filling the tranny doesnt work get ready to pull it apart. GL
Rod.
Nov 7, 2004 01:13 AM
