turbo hf question..
Old Feb 18, 2006 | 02:16 PM
v8hnta's Avatar
Default turbo hf question..
would a crx pm6- off and si work as a boost in gas flow if i were to put it in an hf for added fuel? the car is being turbo'd but wanted to get more fuel flowing in there for less chance of detenation. thanks guys
Old Feb 18, 2006 | 02:18 PM
Stunna MIKE's Avatar
You're going to turbo an HF motor ?
Old Feb 18, 2006 | 02:29 PM
v8hnta's Avatar
Default Re: turbo hf question.. (v8hnta)
yeah i have a greddy turbo kit for a d series motor and i was planning on turbocharging my dx but i dropped a b18 in that. why'd you ask? seems stupid but i only wanna run like 7lbs
Old Feb 18, 2006 | 02:30 PM
v8hnta's Avatar
Default Re: (Aaron EF9)
that and i have trouble getting freeway speed i have to take the access road through two intersections to be able to get up to 60mph
So your turbo'ing an HF motor ?
That will get you like 110whp.
You could of gotten a B series swap for that price and got WAY more power.
Old Feb 18, 2006 | 02:32 PM
v8hnta's Avatar
i traded another crx that didnt run for the turbo kit, and the hf is my daily driver.
Old Feb 18, 2006 | 02:35 PM
Well you should sell the trubo kit and get a swap.
Becuz if its a complete greddy kit, you can get like $2000 for it. And a 1st gen b16 swaped cost around there. With like 40more HP.
And in an HF will be fasst.
Old Feb 18, 2006 | 03:18 PM
Wilson_'s Avatar
Default Re: (v8hnta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8hnta &raquo;</TD></TR><TR><TD CLASS="quote">that and i have trouble getting freeway speed i have to take the access road through two intersections to be able to get up to 60mph</TD></TR></TABLE>
i have no problem with gettin up to freeway speed in my stock (no engine mods at all) 88 hf mabe if you haveing probs with getting up to speed mabe look for other things that might be wrong
Old Feb 18, 2006 | 05:17 PM
godruler's Avatar
Default Re: (Wilson_)
if you use a pm6 to get more fuel into your HF for turbo your gonna have to get some Si injectors because your Hf ones are only like 180cc i think, or get '92-95 injectors and get right of your resistor box, if you do all this you should really get an Si or D15b7 intake manifold and tb because your Hf one is not gonna flow enough air. if i was you i'd pick up a D15b2 or d15b7 or even a d16a6 because you can get either of them for under $150 any day of the week, run those off your pm6 then turbo it, you'll be happy i think
Old Feb 18, 2006 | 08:29 PM
crxnj's Avatar
Default Re: (godruler)
Turboing the HF seems like a waste..8 valve head,very long geared tranny,tiny intake manifold,if you have 88-89 it has 180cc injectors,etc..I dont know what to tell you..Maybe put on a 16 valve head with A6 intake manifold or greater..Get some pistons made for the 16valve head,,and get a pm6 ecu then chip with turboedit and tune it,,or get a 12:1 fmu and High flow inline fuel pump and 6psi or less of boost..And then the tranny is still an issue..
Old Feb 18, 2006 | 09:06 PM
Burlyirishdude's Avatar
Default Re: (Mr.speaker)
yeah plus if this hf is your DD don't throw a turbo on it. If you want a little more power to get up to speed most people don't just throw a turbo on it. I know that Bent Cat at the e.manifold has to go....and you will have to put at least 2" exhaust to get the right b.pressure so you head doesn't float and all this other stuff. You might want to hang on to the turbo idea and just enjoy 55mpg.
Modified by Burlyirishdude at 12:53 AM 2/19/2006
Old Feb 19, 2006 | 04:04 AM
HT Chaplain's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godruler &raquo;</TD></TR><TR><TD CLASS="quote">if you use a pm6 to get more fuel into your HF for turbo your gonna have to get some Si injectors because your Hf ones are only like 180cc i think, or get '92-95 injectors and get right of your resistor box, if you do all this you should really get an Si or D15b7 intake manifold and tb because your Hf one is not gonna flow enough air. if i was you i'd pick up a D15b2 or d15b7 or even a d16a6 because you can get either of them for under $150 any day of the week, run those off your pm6 then turbo it, you'll be happy i think</TD></TR></TABLE>
no all honda mpfi d and b series engines are 240 cc
Old Feb 19, 2006 | 07:13 AM
godruler's Avatar
Default Re: (HT Chaplin)
i know that, i was referring to '92-95 d-series injectors from a b7 or z6
Old Feb 19, 2006 | 08:25 AM
kine462's Avatar
swap a d16a1 or d16y8 in there and then put the turbo on that.. also don't use the hf tranny either it will tach 1800 rpm @ 60mph = not too much fun
Old Feb 19, 2006 | 10:44 AM
Ch3mik's Avatar
Default Re: (kine462)
man just dont listen to clowns. boost it for the fun of it. youll not only learn more but you can also be saving up for another d series in the meantime. once the HF gives up swap in the other motor and boost. Find a good newer nonvtec motor. throw it in there .
Old Feb 20, 2006 | 05:49 AM
v8hnta's Avatar
Default Re:
yeah thats what all my other friends said... since its my dd and all but the last comment, in regards to having fun with it, is partially true, although the motor does suck other than the gas mileage it provides. well if anyone is interested in buying my turbo kit let me know! the number is 214-244-4845 and the name is george. thanks guys for all your input.
Old Feb 27, 2006 | 05:25 AM
v8hnta's Avatar
Default Re: Re: (v8hnta)
sorry guys sold the turbo kit already...
Old Feb 27, 2006 | 05:52 AM
purplecrx's Avatar
If you can't get up to highway speed safely then turboing the motor is not the solution. There is clearly something else wrong here. Clogged cat, or something else maybe? I'd get things checked out.
1990hondacrxhf
May 14, 2007 07:25 AM
slow civic
58
Oct 9, 2004 12:40 PM
1tyme
Nov 29, 2002 08:15 PM
The Brown Kid
Jun 17, 2002 10:23 AM
